[App][Pro] Satel Integra alarmsystem integration
Tests results below. Have not noticed any bugs.
I would correct text terms. Ged rid of from cards words “Day” and “Night” as in fact you can use this modes any time. And accordingly correct capabilities:
This will reflect the names of the mobile app modes and ensure their consistency, thereby avoiding user confusion.
Thanks you for testing and your feedback.
I will adjust the text in a new release this weekend and publish it to live.
If there are more features you like to add let me know I check what is possible.
Thank you very much for the tip. I had to disable the fourth power output (which was left unloaded) to eliminate the issue of the alarm contacts “flickering.” To be able to reset/acknowledge control panel fault alarms, it was necessary to install 2.2 kΩ resistors on each of the main unloaded power outputs (in my case, the third and fourth one).
