[APP][Pro] Rointe: Warm rooms. Your Rointe Nexa Radiators
Hi all,
We have eight Rointe radiators and towel rails, and until now they reached Homey the long way round: a Home Assistant integration, bridged into Homey, with the Group app on top to heat several rooms at once. It worked, but changes took up to 15 seconds to show, Homey offered a “cool” mode the radiators don’t have, and heating depended on Home Assistant staying up. So I built a Homey app that talks to Rointe’s cloud directly.
It works with accounts on Rointe’s Nexa platform: the ones you use with the Rointe Nexa app.
Live, not polled
The app keeps a live connection to Rointe’s cloud, so a change made on the radiator itself or in the Rointe app shows up in Homey within a second or two, and a change from Homey reaches the radiator just as fast.
What each radiator gets
  • Room temperature and target temperature (7–30° in half degrees). Setting a target switches the radiator to heat at that temperature, as the Rointe app does.
  • Heat, Schedule or Off. Schedule follows the radiator’s own Comfort/Eco timetable, and the target shown follows it through the day.
  • Comfort, Eco and Frost presets, using the temperatures saved on each radiator.
  • Heating: whether it’s warming the room right now, logged in Insights.
  • Shows as offline in Homey if a radiator loses its connection.
  • Flow cards from Homey’s standard thermostat set: set the temperature or the mode, the mode is or isn’t, the target or room temperature changed or passed a value, and started or stopped heating.
Two dashboard widgets
  • Heating dial: pick the radiators the widget controls, tap the ones you want (or none for all), turn the dial and press Heat. Off switches them off. Each radiator chip shows its temperature, or its target while heating.
  • Heating groups: named groups like “Lounge/Dining” or “Bedroom/Shower Room”. Tap a group, turn the dial, press Heat. Each row shows whether the group is heating, partly on or off, with its temperature. Tap Edit groups to add, rename or delete groups and pick the radiators in each. Groups are shared, so the same ones appear on your phone and your tablet.
Apple Home and Siri
The radiators work with HomeKitty, so you can bring them into Apple Home from Homey. Each one appears as a thermostat with Off, Heat and Auto (Auto follows the radiator’s own schedule), with no cooling options, and shows Heating while it’s actually warming the room and Idle once it’s reached temperature. That means Siri, Apple Home scenes and automations, and Control Centre all work, without Home Assistant in between.
If you already use the Group app for your radiators, Heating groups copies those groups across the first time it opens, matched by radiator name. After that you can remove the Group app if nothing else uses it.
Getting started
  1. Add a device, choose Rointe, and sign in with your Rointe Nexa email and password. Your password is only used to find your radiators and isn’t stored.
  2. Pick the radiators and towel rails to add.
  3. Add the Heating dial or Heating groups widget to a dashboard.
  4. For Apple Home, add the radiators in HomeKitty.
Not included (yet)
  • The radiator switches: window detection, presence detection, silence mode, do not disturb, frost protection and the local/remote locks.
  • Changing the Comfort, Eco and Frost temperatures from Homey (use the Rointe app for now).
  • Power and energy readings, and Flow cards for presets and the switches.
  • Older accounts on the Rointe Connect platform. If you’re still on Rointe Connect and would like this, please say so.
Tested on eight devices on one Nexa account: a mix of older and newer Rointe radiators and two towel rails. Other Nexa radiators should work the same way, but I’d love to hear from you whether yours does or not. If something isn’t right, please post which radiator you have and what happened.
Test version: Rointe | Homey
This is a community app and isn’t made or supported by Rointe. It uses Rointe’s cloud the same way the Rointe app does, so if Rointe change their service, it may stop working until it’s updated.
Thanks to JYewman, whose Home Assistant integration for Rointe made this possible.
Update: Rointe 0.3.0 is in test
Hi all, a new test version is up.
  • Know when a radiator drops off. Two new Flow cards on each radiator: Went offline (with the reason as a tag) and Came back online. A radiator counts as offline when Rointe reports it offline, for example if its Wi-Fi drops, or when Homey can’t reach Rointe’s cloud for 5 minutes. Shorter blips reconnect quietly without setting anything off. A handy Flow: When Went offline, send a notification with the Reason.
  • No more frozen values. If Homey can’t reach Rointe, the radiators now show as unavailable (“Can’t reach Rointe; reconnecting”) instead of quietly showing old temperatures, and they come back by themselves when the connection does.
  • Reconnect to Rointe action card. You shouldn’t need it, as the app reconnects on its own, but it’s there if you want a manual fallback.
  • The app icon shows properly. The red circle on the app page and the Flow cards were blank; they now show the radiator icon.
  • New pictures for the app and the radiators.
Please test
If one of your radiators goes offline this week, I’d love to hear whether Went offline and Came back online fired, and what the Reason said.
**Update: Rointe 0.4.0 is in test: holiday mode**
Hi all, a new test version is up with a holiday mode, which I wanted for our winter trips.
**How it works**
Tell it when you’re back, and while you’re away each radiator does what you’ve chosen for it:
- **Frost** (the default): low heat, so nothing freezes.
- **Off.**
- **Holiday schedule**: on at set times and off in between. We use 9–12 and 6–10 so the main rooms are warm for our cat, who stays home while someone pops in.
- **Leave alone.**
At the return time, every radiator goes back to exactly how it was: Schedule, Heat at the same temperature, or Off. You can choose to switch back 1–6 hours early, so you come home to a warm house. A holiday carries on through Homey restarts.
**Three ways to start one**
- The **Heating groups** widget: tap **:luggage: Holiday…**, pick the day and time you’re back, and press Start. While you’re away it shows “On holiday until …” with an End holiday link.
- **App settings** (Rointe → Settings): choose what each radiator does, set the holiday schedule and temperature, and start, change or end a holiday.
- **Flow cards**: Start holiday until [date] at [time] (run it again to change the return time), End holiday now, Holiday started, Holiday ended, and Holiday is / isn’t on.
**Worth knowing**
The radiators get their commands through Rointe’s cloud, so if your internet goes down while you’re away, each one carries on with whatever it was last told until the connection is back. Frost is the safe choice; the Went offline Flow card will tell you if the connection drops.
**Please test**
Set it up before you need it: open Rointe → Settings, choose what each radiator should do, and try a short holiday (say 10 minutes) to see it work. I’d love to hear how you get on.
**Test version**: Rointe | Homey
What I’m testing this week & what’s coming in 0.5.0
Hi all, a quick one on what’s going on behind the scenes, as it’s been a busy week with the radiators!
So, did you know a lot of Rointe radiators have a presence sensor built in? It sits in the control panel on the right hand end, and the Presence Detection setting uses it to turn the radiator down when nobody’s in the room. I wanted to know if Homey could use it too, so I sat at the kitchen table with my laptop and walked laps between the kitchen, the lounge & the hallway like a man possessed. The good news, the movement reaches Homey within a second, so it’s quick enough to use for Homey’s zones. The not so good news, once a radiator has seen you it goes quiet for about 10 minutes before it reports again, and our hallway radiator kept reporting movement in an empty hall!
My money’s on the sun, it moves round the bedroom & hallway at midday, so this week the app is recording every movement report from every radiator in Insights. Next week I’ll match them against where the sun was and when the rooms should have been empty, and see which radiators can be trusted. Monté, our cat, is doing his bit for science too, his food bowls are right in front of the dining room radiator :cat:
Also in the works for 0.5.0:
  • Radiators as motion sensors for Homey’s zones, with a switch for each radiator so you can leave out any that get fooled.
  • A timer for towel rails, using the rail’s own countdown timer, so you can have the shower room on for 30 minutes before bed and it switches itself off. Ours turn the room into a sauna if they’re left on!
  • Window open detection, with Flow cards.
  • Flow cards for the Comfort, Eco & Frost presets, and changing those temperatures from Homey.
  • An estimate of power use for Homey Energy.
The current test version is 0.4.0 with holiday mode, and 0.5.0 will follow once the week of testing is done.
Can I ask a favour? If your radiators have Presence Detection, have you noticed it reacting when nobody’s there, and does your room get much sun on it? And does anyone use the countdown timer on their towel rails? I’d love to hear how you get on.
Update: Rointe 0.4.2, now in Dutch, French & Spanish, and off to Athom for certification
Hi all, a quick bump with some news!
Rointe has been through its first certification review with Athom and came back with a list of homework, which in all honesty was fair enough. My drawn pictures weren’t real enough, the widget previews had too much text on them, and the description needed to be more of a tagline. So the app now has a proper photo of one of our radiators in the hallway, a real device picture, cleaner widget previews and a new tagline, “Warm rooms, exactly when you want them.” 0.4.2 is with Athom for review now, so fingers crossed it’s in the App Store soon.
While I was at it, the app is now in Dutch, French & Spanish as well as English. Before anyone asks why not German or the Nordic languages, I checked where Rointe actually sell their radiators, and it’s Spain, Portugal, France, the Netherlands & Belgium, the UK and Ireland. So everything is translated for those countries, the widgets, the holiday settings, the Flow cards, the lot. If Dutch, French or Spanish is your first language, I’d really appreciate a quick look, I’ve done my best but a native speaker will spot things I won’t!
If you have Rointe radiators in your Country and I haven’t added the translation, please let me know.
Also new in 0.4.2:
  • Radiators with Presence Detection switched on now show Motion when they spot someone, and it’s logged in Insights. This is the first step towards using them for Homey’s zones.
  • Towel rails no longer show Motion, as they don’t have a presence sensor (they have a countdown timer instead, more on that soon!).
On the presence sensing, the week of testing is under way. So far the reports reach Homey within a second, which is brilliant, but the radiators go quiet for around 10 minutes after each report, and our hallway one has been seeing ghosts. Monté, our cat, keeps setting the lounge & dining room ones off too, so he’s earning his keep :cat:
Have you got Rointe radiators at home? Which models are they, and does Presence Detection behave itself in your rooms? Let me know your thoughts?
Update: Rointe 0.5.2, towel rail timers, presets & what we learned about the presence sensors
Hi all, 0.5.2 is on its way and it’s a big one!
Towel rails on a timer, with one tap
Our towel rails have a habit of turning the bathroom into a sauna if they’re left on, so this was top of my list. Rointe towel rails have their own countdown timer, and the app now uses it. There’s a new Towel rails widget with four buttons for each rail, 2h, 1h, 30m & 15m. Tap the one you want and the buttons make way for a big countdown, and if you tap the wrong one there’s a Reset button to start again. The towel rails still show in the Heating dial too, so you can heat them normally during the day. Because it’s the rail’s own timer doing the work, it switches itself off at the end even if Homey or your internet takes a break. There are Flow cards too, so you can have the shower room warm before bed without thinking about it.
Also new
  • Flow cards to set Comfort, Eco or Frost, and a “preset is” condition.
  • Comfort, Eco & Frost temperatures are now in each radiator’s settings, so you can change them from Homey rather than the Rointe app.
  • Window open shows on each radiator (when window detection is switched on), with Flow cards.
  • Each radiator now shows an estimate of its power use, so they appear in Homey Energy. It’s based on the radiator’s rated power while it’s actually heating, so it’s a good guide rather than a meter reading.
The presence sensors, and why I’ve stopped there
Some of you might remember I was testing whether the presence sensors in the radiators could work as motion sensors for Homey’s zones. So I left them recording for a week and compared them against what we were actually doing. The good news, reports reach Homey within a second. The not so good news, after each report a radiator goes quiet for about 10 minutes, so Homey can’t tell a room is empty until 11 minutes after you’ve left. The bedroom one missed us walking right past it, and the hallway one reported movement all afternoon in an empty hall, which turned out to be a lamp stood right next to it. Monté, our cat, set the lounge ones off too!
They do the job Rointe designed them for, turning the radiator down when a room’s been empty for a while, but in all honesty they’re not reliable enough to use as motion sensors, so I’ve taken the Motion indicator out and won’t be going any further with it. A proper motion sensor for £15 to £30 does that job far better.
Where it’s at
0.5.2 is uploaded and will follow once Athom have finished certifying the current version. Have you got a feature you’d like to see next? Let me know your thoughts?
Update: Rointe 0.5.5, a bit more private & a bit tidier
Hi all, a quick one this time. 0.5.2 never actually made it out of the door, as Athom came back with a couple of changes during certification, so 0.5.5 takes its place and brings everything from the last post with it, towel rail timers and all.
No more full access to your Homey
Until now the app asked for access to your whole Homey, just so the widgets could reach the radiators. Athom pointed out it didn’t need it, and in all honesty they were right! The widgets now talk to the app’s own radiators directly, so the app only ever sees your Rointe radiators and nothing else in your home. You’ll notice it no longer asks for that permission when you install it. If you’re already using the widgets, your radiator choices and heating groups carry straight over, nothing to set up again.
The one thing that’s gone is the copy of groups from the Group app the first time Heating groups opens, as that needed the same access. If you’re moving across from the Group app, it only takes a minute to make your groups in the widget instead.
Also new
  • The Towel rails widget now fits properly on smaller screens. On our iPad the top line was running off the edge once the countdown went into double figures, so it now shrinks to fit and isn’t quite so bold :grin:
  • Your radiators have their own icon in Homey, so they’re easier to tell apart from the app.
Where it’s at
0.5.5 is with Athom for certification now, fingers crossed for this one! As always, if something isn’t working or there’s a feature you’d like to see, let me know your thoughts?
Can it be combined with the Rointe GENIUS Smart Digital WiFi Thermostat with Touchscreen so that the radiators follow the thermostat’s temperature? This thermostat is supposed to work in combination with the radiators, but so far there is no firmware available for this.
​Kind regards,
Rudy
Hi Rudy, thanks for the question!
In all honesty, not at the moment. The app only knows about radiators and towel rails today, and as we don’t have a Genius here I’ve no way of seeing how it talks to Rointe’s cloud. The good news is it uses the same Rointe Nexa app & cloud as the radiators, so it should be possible.
If you’re happy to help, I can send you a small read-only script to run on a computer. You log in with your own Rointe details, it changes nothing, and it just records what the thermostat reports while you change its temperature. From that I could add the Genius to the app, showing its temperature and setpoint in Homey. Then a Flow could set your radiators to whatever you set on the thermostat, without waiting for Rointe’s firmware.
Each radiator would still use its own sensor to decide when it’s warm enough, but in most rooms that’s close enough. Fancy giving it a go?
I’m definitely willing to give it a try. However, it should work in such a way that the (group of) radiators follow the set temperature of the thermostat, rather than having to create a separate Flow for every single temperature change.
Best regards,
Rudy
Hi Rudy, brilliant, thank you!
And you’re absolutely right, a Flow for every temperature would be no good at all. The plan is to build it into the app, so you pick your Genius and the radiators (or a heating group) simply follow whatever it’s set to, no Flows needed. First though I need to see how the Genius talks to Rointe’s cloud, so I’ll send you a private message with a small script and how to run it.
Rointe is now live in the Homey App Store! :rocket:
Hi all, some good news this morning, the app has passed certification and is now live in the Homey App Store, so you no longer need the test link to get it. Thank you to everyone who’s tried it, asked questions & sent feedback along the way, it’s made the app a lot better!
The live version is 0.5.6, so it has everything from the last couple of updates:
  • The Towel rails widget, with 2h, 1h, 30m & 15m buttons, a countdown and Reset.
  • Flow cards for the towel rail timer, and for Comfort, Eco & Frost.
  • Comfort, Eco & Frost temperatures in each radiator’s settings.
  • Window open, and an estimate of each radiator’s power use for Homey Energy.
  • No more full access to your Homey, the app only ever sees your Rointe radiators.
  • Holiday mode settings that are easier to read on a phone.
To get started, install it from the App Store link below, add a device, choose Rointe, and sign in with your Rointe Nexa email and password.
Homey App Store: Rointe | Homey
