Renault Megane etech also working again, thanks!
Hello @Oreste_Dimaggio ,
Thank you for the updates !
I’m affraid that it’s still not working properly for me, for my Spring.
I can add the device, I can connect to my Dacia account, I can see the usual stats on the device (% of battery for instance), but I can’t neither start or stop the charge.
Using this flow, nothing happens (and same for stopping the charge).
Is it working for you, for your Spring ?
Thank you again !
Still trying to find the correct Dacia Api Call. They keep changing it. Give me a few days and i’ll publish a new update
The Renault megane etech now supports setting the battery limit in the app, e.g 80% for normal use and 100% for longer trips. would like to see this one added.
Thanks Aard, excellent!
Hey @Oreste_Dimaggio , let us know if you had time to check it out ![]()
Thank you !
Please test this version
(click on the link and install it, this is a pre-release test version)
Keep us posted
Thank you so much !
I clicked and tried to install it. It says “Renault and Dacia will install on Homey shortly.”, but I clicked 2 hours ago and don’t see anything. Am I supposed to see a new device (not configured then) ? Or should I search somewhere else ?
Thank you for your help
It will overwrite your existing app.
Just test it out.
Oreste
Oh ok, so I have to reinstall the app before then.
Right now I can log to MyDacia, it says there’s an error, as quite often.
I’ll let you know tonight
It works on the Test app !
Pushing It to production!
Thanks for the feedback!
You can install back the app from the homey store. It Will get auto updated soon!
Sometimes I have to wake-up my Scenic to force him (or her?) to start loading. I do this using the Renault-app and switching on the lights (it does that for a few seconds). Is it possible to implement this in the app? Many thanks!
Hello!
Could you please tell me if there are any plans to add support for the Renault 5 to this app in the future? Thank you for your hard work on this application!
