[APP][Pro] Remotec Technology App (v2.4.3)
Hello guys, I need help with ZXT-600 use on USB powered
I have Senville mini split the remote code is 512 78 51 55 40 48.
I’ve tried built in code library but no luck none of them work. So, I manualy learn the code from the remote.
From learn code, I can turn off, on, Heat, Cool, Dry, Auto, Fan only mode and change tempearature.
But I can’t change fan speed and swing
Question-
  1. To learn code, In Set IR code number from built in code library Box I put ( 0 ) and pick the IR code larning command drop down ( Am I right ?)
  2. How can I learn IR code for fan speed? In the drop down command it have option to learn Dry,Auto, and Fan mode but no option to learn Fan speed. The learning Parameter value mapping table is only from 0-32.
  3. How to make it report temperature? I set it to report every 1mn but it never report It say the same temperature for the past 3 days. (it will update once when I go to Remotec app and it restart app)
I have watched Youtube videos on how to learn code and setup but no teaching for Homey.
Please any reply or idea help.
Even thought all function is not working but I loving to so far. ZXT-600 is Zwave work locally compare to other Wifi based brand will not working if no internet connection.
Thank you and have a great day
