[APP][Pro] Prusa Link
Thank you :+1::ok_hand:
Hi, I have made a flow with print job progress, when I fill in 43 the action takes plase when it’s 44.
Is that normal behavore?
Because when I fill in 100 nothing happens, because there comes no 101 :wink:
Hi, thank you for your great job so far! Im new to Prusa community and Im wondering if it is possible to also push ā€œreadyā€ state through prusa link (as is on a web). So I can for example assign physical wireless button which is on enclosure to set readiness of printer to be able to make another job from queue.
Hi @Paul_Hemels , I will look into this. Thank you for the feedback.
Hi @Pepa_Vlcek
I get your point (great point), I will look into this.
Hi, does any of you have a Prusa Mini+ ? Also one in this community with network knowledge.
I am asking because I would like the app to support Prusa Mini+ but the version of this device differs from the MK device I own. Sad but true, I did a lot of testing with @Karpsson but testing in the blind is not optimal. I also need credentials and access ofc.
Hi @Paul_Hemels
I have not quite sorted this one out. But please consider this case (I also would like some input)
I you set an action in your workflow, for example when percentage equals 44% - this is not safe.
The reason for this is, if you print a short job and interval for updates is set to 1 minute, then certain percentage will most certainly be skipped.
I could make the app ā€œcatchā€ up, to ensure all percentages are triggered. Example:
We get a read from printer at 20%, and we trigger percentage changed = 20%
Next read, we get 25%, remember last change was 20%. I would fire multiple triggers: 21, 22, 23, 24 and 25 in this order, to ensure all percentages are matched.
When the job is done, I am no longer able to get ā€œlast jobā€ details, so it will be hard for me to match your ā€œ100%ā€ hit. Last read: 95% and next read, Job = NULL. We may then assume last is 100% or job failed somehow.
Feedback appreciated.
Hi The 44% was just for test because 100% didn’t work.
If there is a Job finishednit would also be fine.
I have a Prusa Mini +.
If I need to test sommething let me know.
Regards Paul
Hi @Pepa_Vlcek
Regarding the ā€œprinter readyā€ state, we are using the Prusa Link api.
I can only see this option:
Seems lik this only works, when uploading a new file to the printer, then with the ā€œupload commandā€ will a ā€œreadyā€ value being sent to the printer.
I know the Prusa Connect version is different.
What is your take on this?
Hi, it seems to me, that this makes difference between transfer to storage and transfer to storage + queue. If this is the case, it doesnt trigger ready state.
In Prusa connect theres ā€œset readyā€ button. So it is triggerable. But dont know if this is exposed to api. But we can try of course.
Hiya! Did you ever get an answer to this and got the mini+ working!? I have one and will be available from next week probably, not much network knowledge but a bit.
Hi @j_wak , not all data is available but the mini should be supported.
Their app for ios (official), as an example, supports a lot more - but basic information should be available.
I’m trying to use this app with my MK3S+ running a built in Rpi Zero 2 with prusalink installed (official from Prusa).
The printer works just fine with both PrusaLink and PrusaConnect and putting in http://192.168.1.xx/api/v1/status gives me a proper API response.
However when using the Homey app I only get connection error in the Print Job or Prusa Link device when the printer isprinting. I put in the IP and username/password I use on the PrusaLink page on my local lan in both Homey devices (Prusa Link and Print Job).
Is the Prusa RPi Zero supported?
HI @Jorgen_Larsson , can you provide a sample of your ā€œstatusā€-data and I will compare.
Sorry about the somewhat late response…
Here’s the status when I browse to http://192.168.1.131/api/v1/status
ā€œstorageā€: [
ā€œpathā€: ā€œ/localā€,
ā€œread_onlyā€: false,
ā€œfree_spaceā€: 27106025472,
ā€œnameā€: ā€œPrusaLink gcodesā€
ā€œpathā€: ā€œ/sdcardā€,
ā€œread_onlyā€: true,
ā€œnameā€: ā€œSD Cardā€
ā€œprinterā€: {
ā€œstateā€: ā€œPRINTINGā€,
ā€œtemp_nozzleā€: 270.2,
ā€œtemp_bedā€: 109.9,
ā€œaxis_zā€: 1.4,
ā€œflowā€: 95,
ā€œspeedā€: 150,
ā€œfan_hotendā€: 4260,
ā€œfan_printā€: 0,
ā€œstatus_connectā€: {
ā€œokā€: true,
ā€œmessageā€: ā€œOKā€
ā€œstatus_printerā€: {
ā€œokā€: true,
ā€œtarget_nozzleā€: 270,
ā€œtarget_bedā€: 110
ā€œcameraā€: {
ā€œidā€: ā€œenr3T3JnoYV0ā€
ā€œjobā€: {
ā€œidā€: 125,
ā€œprogressā€: 22,
ā€œtime_remainingā€: 24280,
ā€œtime_printingā€: 10171
I am having the same issue. My MK3S has the official Raspberry Pi installed with PrusaLink, and it returns the following status:
   "storage":[
         "path":"/local",
         "read_only":false,
         "free_space":5571485696,
         "name":"PrusaLink gcodes"
         "path":"/sdcard",
         "read_only":true,
         "name":"SD Card"
   "printer":{
      "state":"IDLE",
      "temp_nozzle":22.7,
      "temp_bed":23.2,
      "axis_z":0.15,
      "flow":100,
      "speed":100,
      "fan_hotend":0,
      "fan_print":0,
      "status_connect":{
         "ok":true,
         "message":"OK"
      "status_printer":{
         "ok":true,
         "message":"OK"
      "target_nozzle":0.0,
      "target_bed":0.0,
      "axis_x":0.0,
      "axis_y":0.0
Note that I am running PrusaLink 0.7.2.
Is this still working? I am just getting Connection Error in the Prusa link and print job on any I3MK3 with a Prusalink on a Rpi…. But it’s working on a Prusa Mini
Hi @Prowl_Media
Development is stalled. The ever changing api and api Prusa share with it’s own apps is not public available - not very cool.
Would love Prusa to make an official app themselves.
Don’t know if HomeAssistant has it all figured out…
Im running MK3i with RPi 0.8.1 and getting connection error…
Api reports this:
storage
0
path ā€œ/localā€
read_only false
free_space 12075257856
name ā€œPrusaLink gcodesā€
1
path ā€œ/sdcardā€
read_only true
printer
state ā€œPRINTINGā€
temp_nozzle 214.8
temp_bed 60.0JS:60
axis_z 16.8
flow 95
speed 100
fan_hotend 4200
fan_print 0
status_connect
ok true
message ā€œOKā€
status_printer
ok true
message ā€œOKā€
target_nozzle 215.0JS:215
target_bed 60.0JS:60
job
id 121
progress 38.0JS:38
time_remaining 27900
time_printing 29896
Hi, I kinda gave up on this app. Prusa did change their api on every update and is very quite about their api.
Maybe this has been more solid, but still - many different versions of the api… :confused:
