When switching the simulator “ON” it wil look in the history which event was before the current timestamp (a week ago). And switch the light’s ON or OFF if necessary.
2026-02-06 15:13:16 → Based on event at 2026-01-30 15:12:00
2026-02-06 15:13:16 → Changed: OFF→ ON
2026-02-06 15:13:16 2. 💡 Living room
I’ll publish a test version with debugging enabled, so you can view the logs and all events yourself. It’s on the settings page below tracked devices.
In both cases an additional view is shown with those details. After you enable the simulator you’ll see the reasoning for current actions and scheduled actions. They should match (you can verify in View all events).
I tested it with the test version using one light, and it worked as expected.
The light was on from 19:14 to 19:16 last week. Today at 19:15 it was off. After activating the simulator at 19:15, it was switched on and then turned off again at 19:16.
I’ll test this with more lights over the weekend and report back.
I’ve been testing the app over the last few days, and thanks to the logs everything is working very well.
Is the test version functionally identical to the regular release version?
There’s only one thing, only an idea, left from the earlier discussion:
Ideally, the living room should switch on a few minutes before the lights in other rooms, so the simulated movement pattern throughout the apartment looks more natural.
I do like your apps aproach to simulate presence.
Might it be possible to adjust the import of activities to 30 days? Adjustable?
What I miss too is a chance to adjust the replay pattern. There will always be some activities one doesn‘t want to be replayed or some are missing.
Is it possible to have a random start or stop for some activities as e.g. lights on/ off always at the same time gives watchers quite fast the idea here is a simulation activ.
Oh please do have a look at your texts. Some seem to be available only in Dutch.
First of all thanks for using this app and reaching out to me
Unfortunately these are resolved from Homey device activity and are limited to 50 occurrences.
I had this thought a while ago too, but decided not to interfere with it. Editing the timing/pattern of individual recorded events is a different kind of feature though, and honestly I don’t think it adds much: the whole point of a presence simulator is plausibility, not precision, so small variations in when a light goes on/off don’t really matter. Happy to hear if you had a specific scenario in mind where it would though.
Fair point, someone did mention it before. If simulation starts it triggers all required actions at the same time.
Whoops! I thought I had all translations up and running now. I’ll have another look at it
