Hello community!
Since I have a home battery with a new inverter. The inverter measures solar panels, use of net power and battery power. How do I use PbtH now? Somehow I cannot export the measured power of solar panels and net to a calculator (for total day use and euro’s).
Here is a screenshot of my inverter app (AlphaESS). I hope someone can help me out.
By the way I have a P1 meter, but I only use this for gas, because AlphaESS keeps everything synchronized.
Hi!
I am trying to understand the logic behind the flowcard “The price is one of X lowest of today” when running with 15-minute price periods. I’m experiencing some unexpected behavior and I’m not sure if I have misunderstood the card.
In my Advanced Flow, I trigger the flow every 15 minutes when a new price period starts. In the AND section, I use the card with X=2.
My interpretation is that this card should only return true during the 2 absolute cheapest 15-minute periods of the day (a total of 30 minutes). However, tonight the card remained true continuously from 01:45 to 06:00, even though the price varied during that time.
Here is the exact price data from that period:
  • 01:45:03 – 0.39556521 (Lowest)
  • 02:00:08 – 0.40882248
  • 02:15:03 – 0.42321285
  • 02:30:04 – 0.40791600 (Second lowest)
  • 02:45:05 – 0.41573439
  • 03:00:08 – 0.42207975
  • 03:15:07 – 0.41924700
  • 03:30:01 – 0.41539446
  • 03:45:06 – 0.41516784
  • 04:00:03 – 0.41222178
  • 04:15:07 – 0.41392143
  • 04:30:01 – 0.41596101
  • 04:45:03 – 0.42173982
  • 05:00:03 – 0.43862301
  • 05:15:01 – 0.45482634
  • 05:30:01 – 0.49765752
  • 05:45:05 – 0.53346348
Mathematically, only 01:45 and 02:30 should be true. Why did the card evaluate as true for all the other periods in between?
Does the card internally look at full hour blocks instead of 15-minute intervals when sorting the lowest prices, or could it be a float/rounding limitation when the prices are very close to each other?
How should I interpret this card’s behavior? Any insights would be highly appreciated!
You are correct. I will check if it is a bug
Doesn’t this flow filter on these 2 lowest prices within a timeframe?
That’s quite possible—I haven’t tried that card. In principle, my flow looks like this:
@Krisstenswe I cannot reproduce your issue, nor can I find a bug in the code. Can you show a screenshot of the actual flow you are using, including tags you use? And what app version do you use?
I cannot reproduce your issue. I added a Sessy P1, and it gets picked up perfectly by PbtH Grid driver. Are you sure it is not already added?
Can you share a screenshot of all Sessy P1 device properties and capabilities from this link: Homey Developer Tools
And can you send a PbtH app diagnostics report right after trying to pair?
@Henrik_Johnsson I looked at the latest homewizard app code, and it should work. So a mystery to me why it doesn’t.
Can you share a screenshot of all Homewizard P1 device properties and capabilities from this link: Homey Developer Tools
And can you send a PbtH app diagnostics report right after trying to / doing a re-pair?
those are leftover capabilities from the previous version. You can delete those insights from the homey web gui.
Report 75cbf4d8-a0f3-47f4-8a5b-114158740ec3
Homey did not approve, red popup saying log_not_found.
8.19.0
It’s actually a larger flow, but I’ve stripped away everything that isn’t affected or doesn’t have an impact.
Thnx!
try selecting a longer period before deleting maybe?
I tripple checked the app code, but all seems good there. So I do suspect something is wrong in your advanced flow itself. Try making a very simple flow just to log the 2 lowest prices of the day. If that flow also fails please come back with more supporting data.
Ow, and do update PbtH. It has some app crash fixes.
Did not help unfortunately, same error message.
Updated to 8.20.1, so we’ll see if that helps.
I’m setting up a simple flow and logging, as you suggested – I’ll get back to you.
Thnx!
Still uncleasr why it doesnt work. In the next PbtH release (8.21.0) I added more logging to debug.
Many thx for your kind donation @Krisstenswe ! :smiling_face_with_three_hearts: :heart: :clinking_beer_mugs:
Looks good, Kristofer. Last night the flow
reported a lowest price at two timeframes as expected:
New version 8.21.1 is ready for testing: https://homey.app/a/com.gruijter.powerhour/test/
  • Prepare EV charger driver with self-learning schedule, 15m planning, solar charging and SMART charge modes
  • Selectable capabilities when (re)pairing
  • Fix grid totals reset and peak jump after restart or repair
  • Fix grid, solar and battery history after restart
Again some fixes and behind-the-scene development of an advanced car charge driver.
Most important change for now is that during pair or re-pair you will see a choice of source capabilities to use, select the price source, and set some of the most important settings.
This enables to add many more power, battery and grid meter sources from apps that were not supported by PbtH before!
So go ahead and let me know what you think!
