If that’s true, I really don’t understand how the card is functioning.
This test:
Expected (I guess): the card will trigger the 20 lowest quarters between 20.30 and 23.00 hrs.
Actually: it’s triggering ‘whole day’ (maybe 20.5 is just ignored and only 20 lowest and 23 hrs is considered?). I know there are no 20 quarter intervals between 20.30 and 23.00 hrs (10 only, it is part of the test, as I expected an error when setting), but when I choose 5 cheapest, nothing happens as well.
So, if card is working properly, how to use it correctly?
Update 18-06:
Today I noticed that this card was triggering from 13:30 hrs, while from 15:30 hrs is expected. It seems the UTC time is used for this card. As far as I know there is no setting to correct (in PbtH) and other PbtH cards (I use), use the local and correct time (Amsterdam → + 2 hrs). If something else is the case, please tell me how to solve…
Hi there,
I’m running into an issue where the app stops updating prices every day (or every other day) around 15:00–16:00.
Up until that point, everything works as expected: I receive a new dynamic price every hour and can also see the upcoming hourly prices. However, once it reaches around 15:00, something seems to break. From that moment on, I only see the current price repeated for the remaining hours of the day.
As a result, my calculations are no longer accurate.
Is anyone else experiencing this issue, or does anyone know how to fix it?
Should be fixed in the version i just released to stable
Thanks!
@Marcel_R will be fixed in next release
v8.9.5 is ready for testing: https://homey.app/a/com.gruijter.powerhour/test/
  • Fix several flow cards
  • Work on grid / in-house power forecaster
Enjoy!
Hi Robin,
I’ve recently installed the Homey EMS app by @Kaoh and in that app you can add a Solar Forecast device and I would like to be able to use the PV Monitor device(s) I’ve created for my Growatt Inverters.
I’ve asked Vincent which capabilities are actually looked at, I hope you can tell us which capabilities are actually used by the PV Monitor device.
Thanks!
ill add support for this one :slight_smile:
there are no standards in Homey for this type of device (solar forecast) so I need to find them based on popular apps unfortunatly. I did not find this one before (analysed it as tarifs missed it included solar also). But looks promising.
Give me a sec to add support this one :slight_smile:
How can you create the solar forcast device?when i try to install it i don’t see the option.
Which app version is currently installed?
Should be v8.7.0 and up
then that is the problem, i am running 8.4, just wondering why it’s not updating.
I am now also using this app for my solar predictions, very nice and accurate, impressive. One thing I noticed is heavy on memory usage. Is that a config thing I can change?
Version 8.9.5 is out in stable.
Go to the https://homey.app/a/com.gruijter.powerhour/ in Homey and add the app to your Homey. It will replace the current version.
No prices for tomorrow. Am i the only one?
No, upstream ENTSOE has no prices either.
Same here. And same for Homey Energy. Although, prices are available in app of energy company. And all use same source(?)
Not all, some have Nordpool as backup. But eventually it comes to the same price but depends when each of these sites share these.
Xadi and kwhprice point to ENTSOE so if nothing is made available there those sites also don’t have it.
@Gruijter Maybe Live energieprijzen voor dynamische stroom in Nederland | EpexPrijzen.nl can be used as a (fallback) source. Last weeks they didn’t miss any data.
PBTH is used throughout EU/World. So I wont implement a fallback that only covers NL.
I understand and created a fallback using Homey Script for my Homey (it took 10(!) minutes asking ChatGPT to create the Homey Script that fetches the data using the API and get it running).
This doesn’t solve missing data when using PbtH flow cards, but it does for my ‘Energy Report’. Anyway, the data became available in PbtH and Homey Energy yesterday evening, so I’ve to wait to fully test my fallback script+flow. :grin:
