[APP][Pro] Portainer – Docker container management & monitoring
:spouting_whale: Portainer for Homey
Monitor and control your Docker containers directly from your Homey dashboard and Flows.
App Store (stable): Portainer | Homey
Test version: Portainer | Homey
What does it do?
Portainer for Homey connects to your Portainer server and brings your
Docker environment into your smart home. Keep an eye on all your
containers without leaving the Homey app — whether they are running,
stopped or have crashed.
Features
Dashboard widget
  • See all your containers at a glance
  • Status indicator (running / stopped / crashed)
  • Memory usage per container
  • CPU usage per container
  • Start, restart and stop containers directly from the widget
  • Search and filter containers
  • - Switch between Portainer environments using the filter bar, or select ‘All’ to view all containers at once
  • Offline environments are dimmed and can be hidden with the eye button
Triggers (When…)
  • A container has crashed
  • A container has started
  • A container has stopped
  • Server went offline
Conditions (And…)
  • Container X is running
  • General alarm is on
Actions (Then…)
  • Start container X
  • Stop container X
  • Restart container X
Requirements
  • Homey Pro (v12.3.0 or newer)
  • Portainer CE or BE running on your local network
  • Portainer API key
Roadmap / Coming soon
  • :white_check_mark: ~~Environment filter in the widget~~ — released in v1.1.3
Support & feedback
Found a bug or have a feature request? Reply below! :backhand_index_pointing_down:
Great app! Thx…
I just switched from Portainer to Dockhand though… ;(
:white_check_mark: v1.1.3 is now live!
What’s new:
  • Environment filter in the widget — switch between Portainer
    environments or select ‘All’ to view all containers at once
    the eye button
  • Fixed container list scrolling
How to update:
Simply update the app in the Homey App Store. If the new features
don’t show up, try re-adding your Portainer Server device.
:link: Portainer | Homey
