[APP][Pro] PoolWise — Smart pool automation
Hi all,
PoolWise is a test release of a pool management app for Homey Pro. It runs the pool on its own using the devices you already have in Homey (relays, pool probe, heat pump, solar…), and learns from your pool day after day.
What it does
  • Daily filtration time from water temperature and weather, placed at the best hours (sun, solar surplus, off-peak, or before dawn in winter)
  • Up to 3 pump speeds, salt chlorinator and pH regulator, with ORP-based chlorination
  • Safety: frost protection, storm stop (lightning sensor or forecast), flood cut-off, dry-running protection, heat pump flow guard
  • Learning: self-adjusting filtration time, early chlorination before ORP drops, swim detection from the probe, learned night cooling (optional)
  • Swim / party mode, shock treatment, holidays (presence-based), lights, topping up (level sensor or evaporation estimate)
  • Optional EDF Tempo support (France), solar surplus and home batteries
  • Settings page with history, “why?” journal, dosing calculator, season guides
  • 4 dashboard widgets: animated pool, quick controls, water quality & schedule, pool weather
Requirements
  • Homey Pro (local app)
  • At least a relay for the pump; a pool probe (temperature, pH, ORP) is strongly recommended
  • Everything else is optional
Install (test version)
Open it while signed in to the Homey account linked to your Homey Pro.
Getting started
  1. Install the app, then add the device “Pool”
  2. Open the app settings and follow the setup wizard (sensors, pump, speeds, chlorinator…)
  3. Turn PoolWise on — nothing is controlled until you do
Known limitations
  • Test release: please check the schedule before leaving it fully unattended
  • Tested so far with Shelly relays, an ICO probe, Zendure batteries and an APsystems inverter
Feedback welcome
Bug reports, device compatibility (other probes, variable-speed pumps), translations (EN / FR / DE / NL). Screenshots of the settings page help a lot.
Thanks for testing!
:france: Les retours en français sont bienvenus aussi.
