[APP][Pro] Polestar
Good morning,
Used to use the app in both direct mode as well as using Car Stats with my previous PS2. Now after 5 month, of no Polestar I got my new PS2.
I am trying to reactive my flows and most of the stuff seems to work fine in both modes.
Unfortunately it seems I can’t the get the “Trip Ended” card to work in Car Stats mode. Is this still supported ? The correct data is shown on the tile (especially the location) but the flow card does not seem to “share” the corresponding tag.
Any idea? Thx!
I haven’t looked at that event in some time. Not sure
Is there something going on with the app? Last update of values is from 4 days ago?
Still not working. Is there something wrong or am i doing something wrong :)? @Kaoh
For me it still works
Are you using the car device or the csv?
I´m using this:
I tried to install it again but it says “no new devices have been found”
edit. removed old device and installed it again worked.
I released an update that should ensure the car shows up in the energy dashboard as ev. More important it is recognized as ev now by homey for other future support
@Kaoh P4 owner here. Would be pleased to help with any testing if needed.
Works great with a P4! Shame that their API does not allow updates since the P4 only has one climate timer…
Indeed, my own P4 is two months away, so expect some improvements if I can find them :joy:
I allready see the P4 in my own Homey app before I even got a delivery scheduled :smiley:
Its charged to 43% right now :slight_smile: no license plate registered yet.
Very cool! You will love the car.
What is not available is Power, Energy and Current - which would be good to have. I used this with the VW Connect app before the Polestar to notify me if the car was not pulling enough W/KW from the charger.
It just gives Invalid Token in the flow cards now.
Yes they removed those from the api recently. I kept them in in the hope they show back up some day
Ah, I see! That’s a shame. Hopefully they will be reinstated at some point.
@Kaoh any clue why this is happening?
Then you switched network layer, so utp/wifi/docker is now leading. Repair the device to renter the password to encrypt using the now current network layer. I do this so your password can’t leak from backups.
Yep, removing the device and Installing it again solved it :+1:
Anybody experiencing issues? My device stopped working two days ago. I’ve tried removing the device from homey, adding it again, removing the whole app and reinstalling, repairing etc but it’s always complaining about wrong credentials (which they are not, I tested on Polestar’s login page as well as in the app with the same creds). If I check the debug log it says:
“Retrieve vehicles failed - cannot read properties of null”.
Same here my Polestar credentials are good. But i cant log in.
Thanks for the app update! However, the vehicle still cannot be added. It recognizes a vehicle, but only as “Error”, at least for me.
Try the new version
