[App][Pro] Playstation
Thank you :folded_hands:t4: that worked :flexed_biceps:t4:
So I have tried it more times now but I comes out with the same outcome. Timeout after 30000ms.
But last time I tried now it came out with an error stating that there was no PS4 on this adress. Even tough I´m using the same IP-adress. It is set to static and I have checked that its right.
So what could it be?
Since the pin from the PS-console comes out with 4 digits, a blank space, and then 4 digits. Like this xxxx xxxx. Should I enter the pin with the space between or not? Have tried both alternatives.
Also I´m wondering if there could be some issue with the bandwith? Is it a problem that the PS4 is on 5Ghz and the Homey on 2,4Ghz? Same network name but different bandwith?
And lastly. In the original instructions it says that you should retrive a 64 character token. I haven´t found a place to enter this, so I guessed it´s noe longer use for it? If not. Where do I put this?
Bandwidth does not matter
Token is only for PSN device.
I dont remember what i used as pin format, but you tried both, it should have worked
You can try sending me a diagnostics Report after you get the error.
Ok so now I tried once more. Same errors.
Here is the diagnostic report for the error that states the PS4 is not on the same network:
6eea1416-91a7-419a-ad86-4b57d950e96e
Here is the report for the timeout error:
d07349ef-6727-47fb-9b8b-7760d94ae1a8
Here are the logs for the second error (first one is false negative)
Registering with device via Second Screen.
Open the PS4 Second Screen app and attempt to connect to the device named:
PlayActor
I’ve seen this error a couple of times in this thread. Dont know if anybody solved it yet.i dont have a ps4 to test myself
Ok, are you refering to the PS4 Second Screen app on a phone?
On ps5 is on the settings screen in the ps, not in the app. So i think it should be similar, maybe where you set the pin
Hi, I have a strange issue with this app.
I uninstalled it a long time ago, but today I noticed it still turns up in my logs.
to solve this, I tried to install the app and then uninstall it again.
In the print screen added, you can see a dip in memory when I installed the app again.
Then I uninstalled it, but it still shows up in the logs.
Does anyone have experienced this behavior before and know how to solve it?
I’m trying to add a PlayStation 4. However, after filling in the IP address, account ID and PIN code, followed by clicking the checkmark in the upper right I first get a spinner and then a red banner appears that informs me that there was a timeout after 30000 ms.
How to fix this?
(I can ping that IP address; I verified the account ID and I tried to link multiple times, with different pin codes; typing both 8 digits in a row and with a space in the middle as the PS4 shows it - all in vain)
