Look already taken?
Not yet. Busy times ![]()
good thing is the images are only referenced by url by this app, so they are not saved in your homey using resources (at least only urls are saved), but still checking this on the forum as you saw
I saw indeed. But I noticed opening the images in developer-mode takes a lot of time (most of the time it even freezes). Which I checked because I use the images on my Homey for my dashboard (SmartDash). But indeed it is not a big problem ![]()
Almost ready to test?
Same issue for me, did you get to fix it?
Not yet. I have for my own homey a restart scheduled each night
App restart also does the trick
Hello, I have the same problem. I think I have filled all fields correctly, but still with the same results - Network request failed. report n. 832DC09C
thank you for help
Should work after a minute (if you use a minute as poll time). Did you check if your TV doesn’t do this automatically? I use hdmi eArc for this but maybe other hdmi work as well
Hdmi earc is a bullshit lol the problem is that when you turn on your tv the ps5 turn on too…it seems to be a recurrent problem with Lg tv…
That the reason why i try to use your homey app
I will try to put few second.
Hehehe I didn’t know that issue. You can also create a flow that turns the PS5 and tv on. And launch the flow from homey or with a Zigbee button from IKEA or voice command from Google assistant
The ps5 has to be on standby ( orange led) !!!
and the Tv turn on…
on 20 secondes…
Next step…select the source ps5 on automatic lol
Great! It might take max 1 minute, depending on how far the counter is , so average 30 seconds
i think you can choose in ps5 settings (HDMI CEC or something) if ps5 should be able to wake tv and/or if tv should be able to wake ps5, this will work even if ps5 is turned off and not in rest mode.
I had the same problem as you when turning on my lg tv it would also turn on my ps5.
Problem went away when a lg webos update made it possible to start the tv into home screen rather then HDMI
New version 1.8.0 (on test now, will be released very soon)
Widget available!
I’ve begun to work on a widget and I have some basic functionality:
show the avatar picture, user name, artwork of the current game, trophies of the current game and total trophies of the user.
I’ll be trying to add more information on the empty blocks
Happy with my work? Your support to continue developing this and new apps is always appreciated.
- Donate with Paypal
- Support me on Patreon
- Cheers!
in the morning
in the evening, all fueling my enthousiasm: https://www.buymeacoffee.com/emi662002
Coming soon:
More widget work when I find the time and inspiration
Do you have any ideas or suggestions ? Don’t hesitate to leave a message!
Hi
I’m having the same error (Network request failed), have you found a solution to the problem?
This is maybe me facing a first world problem… BUT the feature I would really love to have is to change the play time on my daughters account.
this is on the WAF aspect. I have the PS app so I can ad 30 minutes to play time anytime I want. but I’m often on a trip and then it’s on my wife. I’ve suggested that she could install the PS app and create a playstation account so she could do this herself but for some weird reason she prefers to text me to ask me to add time. It’s the same when she wants to override the car charger schedule.
Car charger I solved by giving her a shortcut on her phone, with this app, it would be awesome if I could do the same ![]()
Yes, again. a real first world problem. but isn’t that why we are into homey in the first place ![]()
I didn’t see any docs in the API about this. Let me know if you find something
