[APP][Pro] Pipup
The Apps works fine in my case on Philips Android. Thanks you !
However, when I display an image, the accents no longer seem to work. When I view a message without an attachment, it works perfectly. Is this a problem on my side?
Thank you, have a nice day
You need to allow Settings->Integrity->Special app permissions->Show above other apps->PiPup.
In Google ? Or homey?
@Xavi2503 It’s in the settings for the Chromecast with Google TV
Did turn on as you said but unfortunately not working
If I follow the steps I can’t get it to work.
Hi.
Can anyone tell me where I can find the APK for the android TV?
I can’t get access to it via the Play store?
Best regards
The test version is no longer available :cry: https://play.google.com/apps/testing/nl.rogro82.pipup
Not sure of this is latest beta, but perhaps this is useful:
https://m.apkpure.com/pipup/nl.rogro82.pipup/download
Good luck
Did anyone get this working? I used this repo, but didn’t worked: GitHub - desertblade/PiPup: Enhanced notifications for Android TV (I did not did “On Android TV (8.0+), when sideloading, you will need to set the permission for SYSTEM_ALERT_WINDOW manually (using adb) as there is no interface on Android TV to do this.” as I wasn’t sure if it is always required?, since I already enabled “Draw over other apps permission: Permission required to create an overlay”)
Also tried the newer version GitHub - gugutab/TvOverlay, but I think it is not supported?
@Michel_van_Lier I have created a Homey App for TvOverlay
[APP][PRO] Tv Overlay - Apps - Homey Community Forum
I also created a new APK from the source of PiPup you can download it from my GitHub page:
Releases · steffjenl/PiPup
