Show a snapshot of your camera on your TV (eg on a motion trigger)
Display a notification with the video of your camera when someone is at your door
Send a notification when your dryer/washingmachine is ready
Anything else you might find useful
The application is currently in a public beta
Send notifications to your Android TV using Homey
Note: First install the application “PiPup” on your Android TV.
*Important: after installation / updating it is currently adviced to restart your TV and open the application once to make sure the background-service is running
The Android TV application is currently in a public beta
This sounds exiting. I have installed the app on the TV (Sony) and it shows the server is running with the TV’s IP address and a socket number.
I have installed the Homey app and created a flow to send a PiPup message to the TV but nothing happens.
Should the address entry in the PiPup card contain just the IP address or include the socket number as well?
I have tried both but would be good to know for sure.
Any suggestions on what to try to see which end is not working?
It’s just the IPadress.
But maybe i forgot to mention an important thingie:
Will add that to the OP, lemme know if that works for u.
Hi Adrian,
I have the same experience here.
Although I installed it on my Nvidia shield.
All went well, setup on shield.
Restarted Shield and directly started pipup.
Created flow in Homey and entered correct ip-address of Shield.
I think i setup everything completely, but with tests the Shield seems not to receive any information to show in pipup.
Please also supply the version of Android TV so I can check.
I only have two sony tv’s but i will try to find someone with a Shield.
One thing you can check is if all the app permissions are correctly set. Basically on newer Android TVs (8.0+) the permission SYSTEM_ALERT_WINDOW should be set and normally the Google Play Store should automatically set this on installation because Android TV has (or perhaps had) no dialog to do so.
If someone knows how to connect to their TV using ADB then you could try:
adb shell appops set nl.rogro82.pipup SYSTEM_ALERT_WINDOW allow
Have the same experience on my Shield, everything set up but no pip on shield. Have motion sensor in front yard, activating my IP cam installed on the same wall, test works ok, but no data on the shield! App and everything installed ok!
I removed the prevous version and installed the latest version.
Unfortunately that did not change it.
After that I installed an app for adb support on my phone and did the adb command as described.
Now I do get a popup screen from homey on my shield, but only the texts. The expected image is not shown (yet).
I use the same tag for notifaction by email and that works so the image should be okay, but the shield does not show it.
Thanks for the great work
Gtz Eric
I just tested it with another actioncard where i could enter a image-url and that works great.
So the app works like a charm, thanks for that.
I think the image tag is just not ready when the popup want to show it…
But thanks sofar, i love it
Hi Guy’s, great app!
I installen it on a Philips oled903 Android 8.
The app is running, dit not do the adb commant there is no popup comming on the tv.
Is there something I can test?
