@johan_bendz Can you add in your first post the Filament G125 to this list. Prevents some questions.
Thanks @rvdeijk, there was a number of devices that needed to be added to that list ![]()
Hi @Pieter_Tack, that’s a new product ID. I just added it to the code and it will be supported in next update.
Many thanks!
Is there a way in which I can receive an automated message if the app is updated? I cannot seem to find an RSS or subscription button or anything.
I can post here when I update. If you click the bookmark on my top post you will get notified when it changes.
New version of the app: v2.0.13
Added support for:
- Calla Outdoor Tall Path Light
- Appear Outdoor Wall Light (Upper and Lower)
And added a few product ID’s to already supported devices.
Hi everyone.
I have an early Christmas gift for all firmware 4.2 users.
As a special update I will for a short while remove the Test version (firmware 5 version) of the app from the App Store and update the Live version (firmware 4 version) with new product Id’s and new devices.
Before I can do that I would however need a bit of help to gather device and profile id’s for some products.
Bulb 1600 Lumen White - LWA009
Bulb E14 Candle White Ambiance (BT) - LTE002
Calla Outdoor Tall Path Light - LCF005
Runner Single Spotlight - 5309031P9
Appear Outdoor Wall - 1746330P7
Econic Hanging Wall light - 1744030P7
The information I need is:
deviceId:
profileId:
Thanks in advance! ![]()
That’s a nice Christmas surprise! Then I would have full control of the Filament G125 inside homey instead of just the on/off ability ![]()
Can’t help you though with the devices you are asking. ![]()
Hi Johan, would it be possible to branch down this feature to 4.2 too?
THX in advance!
Hi @johan_bendz,
The motion sensor updates its light sensor by default when motion is detected (in the original Hue Bridge).
Since I need a light-dependent control, I lack this functionality with the motion sensor.
The lux value is not updated together with a movement.
I can influence the polling of lux and temperature in the “Advanced Settings”, but somehow it doesn’t seem to work. Is there still a problem with the sensor query, or how do I have to change the setting for a simultaneous update of the movement + brightness?
Do you know another way the brightness at the same time! together with a movement?
Thank you for your time and the fantastic app.
Hi Johan,
Could you add the color loop as well, so nice to use during Christmas ![]()
Keep up the good work!
Many thanks!!
Hi @Tregobad, the device have commands and attributes. A command is when motion occur, then the device sends a command to Homey telling Homey to act on it, eg. trigger a card. An attribute is updated on every change but only reported to Homey according to set parameters, eg. when x change have occurred, at least every x minute etc. I will have a look at what I can do to have it report an attribute when a command is sent. It’s not by default done that way.
Hi @Joka. Sorry, no… I will not add any such code to the 4.2 version. Let’s hope firmware 5 is around the corner.
Hi @Pim, I might… no promises! ![]()
What I do have in releaseplan right now is support for power outage behavior, eg. what the lights should do when power has been restored. (off, on with defaults or last status) ![]()
Take your time Johan, priorities first.
Thanks!
Hi @johan_bendz i bought a philips aurelle square but if i connect homey detect it as unknown device. Product ID: 3216231P6 are there different versions? Because in the app i can see those panels . Btw i tried to do a interview but it stop in a timeout. I use Homey 5.0 and the test version of the philips hue zigbee app. Thanks for your help
All bulbs are offline, where can i get the last version to overcome the problem?
Auto Update was faster than me ![]()
Same issue here… ![]()
Never change a running system:)
I always switch off auto update when everything works fine
