[APP][Pro] Peblar EV Charger - Plug in. Power up. Automate
This is completely unrelated to Homey.
Did you reboot your charger already to see if that fixes it?
Thanks for your quick reply. Yes I did reboot it several times. I will make contact with Peblar again.
Dear Kyle,
After the reboots i can inform you that everything is working accept the link to change the settings how to charge .
When i want to change the setting from normal to snel I recive : login failed :HTTP 401
Best regard
Maarten
Did you put the credentials in the app , like described in the first post ?
Kind reminder
Did you try what MarcoV said?
Also there is a brand new update and please everyone in the topic let me know if something breaks, nothing should break… but if something breaks please re add your charger.
This is a larger update based on feedback from this thread, especially around better charger control, more telemetry, Flow support, and multi-language support.
What’s new since the previous public version:
  • Added 1F / 3F phase control, including Force 1 phase support.
  • Added live charge limit and configured maximum charge limit controls.
  • Added per-phase telemetry for voltage, current, and power on L1, L2, and L3.
  • Added Peblar charging state support, including better cable/charging state detection.
  • Added warning, fault, and alarm-code information.
  • Added firmware/customization version information and firmware update detection.
  • Added LED brightness, buzzer volume, LED Automatic/Off actions, and reboot support.
  • Added many new Flow cards for charging, phase mode, charge limits, warnings, faults, online/offline state, and smart charging modes.
  • Updated widgets for charge limit and smart charging mode control.
  • Added editable device settings for hostname, API token, and Web UI password.
  • Migrated old global settings into per-device settings, so existing users should not need to re-pair.
  • Added an advanced setting for users who really have more than one Peblar charger.
  • Completed translations for all supported app languages.
Important note:
If you already had the app installed, your existing API token and Web UI password should migrate automatically into the device settings. If something does not work after updating, please first check the device’s advanced settings and confirm that the hostname, API token, and Web UI password are filled in correctly.
Thanks again to everyone who tested, reported issues, and suggested improvements. Please let me know if anything behaves oddly after the update, especially around migration from older versions or white-label Peblar chargers.
Yes , I have seen and i did everything as discribed.
I will download the new update.
Thanks best regards
Maarten
To inform you that the app is working now.
I have disconnected the option Mobiel- Netwerk.
Please only connect Ethernet and WIFI
Best regards
Maarten
Hi Kyle,
I really love the app that you build! I did noticed though that Charged Energy now only shows the cumulative energy charged by the charger. In previous versions this was the energy charged this charging session. Is it possible to return the possibility to see the amount charged this charging sessions?
Thanks in advance.
Goodmorning!
Thanks for this great app! I’ve recently had installed my Peblar EV charger and currently waiting for my EV to be delivered.
Yesterday for testing purposes a good friend of mine had his car charged at my house for a couple of minutes to test out the connection. Was working great, although I have a question.
When I open the Peblar dashboard I didn’t see any errors or faults, just the amount of Wh which was charged.
In the Homey app however I saw multiple indications of an error. How is that possible?
See below screenshots. Do I have t create an error report?
Hi, I want to create a Homey flow based on the last used RFID token from my Peblar Home charger. However, the variable ‘Last used RFID Peblar EV charger’ always returns ‘empty’. The variable ‘Last read RFID token’ throws an error. Is there a way to retrieve the RFID token that was used to start the charging session?
First of all, please edit your comment so its in English.
Secondly, I think you confuse my app with the official Peblar Homey app as this one doesnt offer any RFID functionaly at the moment.
Thanks! I’ll post my question with the other developer/app.
I did a quick search and honestly I dont know how he would even keep track of the last scanned tag as I currently only see a way to get which tags are registered but not when they are scanned
Is there any Dutch Peblar Business user here that has the charger connected to a backend for EV charging reimbursement through the lease agreement?
I’m getting mixed information from providers :frowning:
I want to know if I can still set the desired charge mode myself in the app (and thus from Homey) while connected to a backend.
Yes, me!
Its more like they manage the sessions, or rather monitor and RFID cards. But thats it every thing else you can still control completely locally.
Thanks Kyle, may I ask which backend you’re using, I’m currently looking into Blue Current as this is the party our lease comoany is working with.
It was GroenDus from Ayvens. The only thing I mange in the only back office is what RFID cards are excepted and if for that RFID card, either I pay for the charged power or the owner of the tag does
Hi Kyle,
I think there’s something wrong with the flow rate, it seems to be of by a factor thousand, or it’s in mA and the displayed unit is wrong.
I’ve also seen this in the capabilities on the device but didn’t screenshot it. I see this on all 3 phases.
The max charge limit is ok.
App at 4.2.8
Peblar Business at firmware 1.9.2+1+WL-1 & Peronalisatie firmware Peblar-1.15
Let me know if you need additional information.
Hi, I’m facing an issue which I think is app related. When the charger pauses due to load balancing it does ‘t restart. Previously i ran the homey intégration through homey script and didn’t face that issue.
Any thoughts?
