The testversion 1.1.12 includes a fix for the timezone adaption on FW 7.4.x for teh AirQuality devices.
It would be nice if someone (perhaps @CorvanderNiet ) could test and give a short feedback if the date is correct now - for setting this version live. Thanks.
Device option to deactivate the automatic polling.
You can deactivate the automatic interval polling in device settings for the “location” devices (weather and air quality).
Flow action for one time refresh of “location” devices.
With this flow action you can update the device date with a flow. This way you can choose the time for update like once a day a a defined time.
@Dennis_H74 Perhaps this could solve your problem with the changig data in forecast devices. I know, the data at morning is not closest some times. But this way you could add a second location (current weather) and a assigned forecast device. Deactivate the polling in device settings. Add a flow started a a wished time and use the flow action of the current weather device to update the data.
Caution: The processing of flow actions is asynchronous. So you can’t read the updated value in this flow. You need second flow with the “data has changed” trigger.
adjusted timezone handling for sunrise/sunset to be compatible with FW 7.4. It would be nice if someone with FW 7.4. could test if the time is displayed? Thanks.
Thanks @all for your test. If a time is shown ist good. If it’s the correct time for your timezone, it’s best
So it seems all is ok and I’m waiting for Athom to rewiew the version tomorrow.
Don’t know if this is the right topic, but I’m a rookie with the values, it’s all very unclear to me.
I wanted to create flows for each sensor, to inform or warn me about bad or dangerous levels
I found this:
Fine particulate matter (PM2.5)
5 μg/m3 annual mean
15 μg/m3 24-hour mean
Coarse particulate matter (PM10)
15 μg/m3 annual mean
45 μg/m3 24-hour mean
My installation V1.1.14 appears to have stopped reporting the 24 hour forecast maximum temperature and minimum temperature. Last update for those fields was 2 months ago !
