[App][Pro] OpenWeather
Hi Ronny,
I will keep an eye out for it happening again, then generate a Diagnostic Report as soon as I can after it happens. It seems to happen fairly often
Hi Ronny,
I have just caught it happening while it was just starting to fail.
Diagnostic Report ID: 35134a6e-e99a-4023-8911-f031e1943d1b
I have 2.5Gb home LAN, with 900Mb symmetrical broadband with 6-8ms latency, that I regularly monitor. I also have a number of ping and port monitors setup on my Homey Pro to both LAN and WAN hosts (average response times LAN 1.6ms WAN 11ms google HTTPS port). So I am reasonably confident that my local network and internet connection are not a problem (first thing I checked). And I don’t seem to have any problems connecting to OpenWeather’s website or online weather map.
I hope this helps.
Thank you kindly good sir :saluting_face:
It’s just a timeout error during http call. I can’t see any details (as it would be the case if the API is returning an error). Hard to say what’s wrong.
Okay Ronny, thank you for looking. I’ll keep looking and testing, see if I can figure out what is causing it. What’s weird is it only seems to affect the version 4.0 API, and not the older versions.
EDIT: My other thought was if it was the daft USB 2.0 480Mb/s bandwidth restriction of the official gigabit Ethernet adapter… that’s the only bottleneck on my network, and Homey is the only device on my home network I have any time-out issues with. As discussed previously in another thread with Abe @Doekse.
I haven’t found a default timeout for http.min module. So I added a 10sec timeout.
Perhaps the API is a bit slow from time to time.
Please try the test version if it’s getting better.
New test version 1.8.6:
  • Added http timeout. Fixed API error message.
Hi Ronny, thank you, I’m not at home today… but I have sent it to my Homey, and I’ll check my monitoring and logs when I get home.
The USB 2.0 bandwidth limitation really shouldn’t be a factor here. While the official Ethernet adapter is indeed limited to 480 Mbps, that’s still vastly more bandwidth than Homey needs.
Homey primarily exchanges small amounts of data for device communication, API requests and status updates. Even a 100 Mbps connection would be more than sufficient for that.
More importantly, bandwidth and latency are two different things. A 480 Mbps connection doesn’t inherently introduce additional latency or cause timeouts. That would only become relevant if the connection were actually saturated, which is extremely unlikely under normal Homey usage.
I would just like to submit this evidence your honour, for the court’s attention…
Multiple 4K camer streams being converted to webRTC by Homey and sent to multiple dashboards, along with various other data. A Homey Pro with 500 devices, 285 Advanced Flows etc… I think I could be testing the limits of USB 2.0… which even though it has a maximum advertised bandwidth of 480Mbps, doesn’t necessarily always achieve that throughput.
