[APP][PRO][OFFICIAL] SolarWatt - Powering a better tomorrow
Connect your SOLARWATT vision devices to Homey over your local network (Modbus TCP). No cloud account is needed.
test version: Solarwatt | Homey
Supported devices:
Inverter vision: solar power and yield, inverter output, house consumption, grid values and alarms. You can limit the output power and the feed-in to the grid.
Battery vision: state of charge and health, power, energy, temperatures and alarms. Homey can charge and discharge the battery, and you can set the work mode and SoC limits.
Grid meter connected to the inverter: power per phase, imported and exported energy, voltages.
Charger vision: charging power, energy and phase values. Start and stop charging from Homey.
Requirements: Modbus TCP must be enabled on the devices (ask your installer), and Homey must be on the same network. Give the devices a fixed IP address in your router. They are found automatically; otherwise enter the IP address yourself.
:warning: SOLARWATT Manager: if one is installed, it can take control of the battery and the power limits back from Homey. Homey then shows ‘Control overridden’ and leaves control to the Manager until you change a setting again. To control the battery from Homey, make sure the Manager does not control it (ask your installer).
reserved for future use
Hey, i would like to help and share my account for the Solarwatt if needed.
If any SolarWatt owner is using Fox ESS as cloud service, please help app development here: [APP][Pro&Cloud][Official] Fox ESS - Test accounts needed for development
TEST VERSION IS NOW AVAILABLE:
Note that this is a test version, so expect bugs and breaking changes in the first release.
Local Homey integration for SOLARWATT vision devices.
Supported devices:
v1.1.0 is ready for testing:
  • Improved solar and AC vs DC capability mapping
  • Migration improvements
  • Flows no longer run twice
  • Slider ranges are restored reliably after an update
New version 1.2.0 is ready for testing:
  • Fixed force charge and force discharge
  • Added EV charger session
  • Added active energy limit
  • Added stop reason and faults
  • Added start charging setting
  • Improved override detection
  • Added inverter power per phase
  • Added second meter readings
  • Added many flow cards
  • Improved icons and titles
  • Fixed battery power limit of 0 W
  • Improved diagnostic logging
When all is good, this version will be released as stable in the Homey app store.
Version 1.2.1 will be released as stable soon:
  • Removed battery alarm
  • Battery faults are now reported by the problem alarm
  • Improved single-phase inverter detection
  • Improved app store images
The app has just been approved by Athom as stable release:
New app version 1.3.0 is ready for testing:
  • Fixed SoC limit sliders showing the wrong percentage
  • Force charge now stops exactly at max SoC
  • Pairing finds devices by a network scan when mDNS sees nothing
  • A device that changed IP address is found again automatically
  • Added a setting to keep a fixed IP address
New version 1.3.1 is released as stable:
  • New devices start with the right capabilities right away
  • Fixed battery and charger settings changed quickly after each other being applied wrongly
  • Minor other fixes and improvements
Thank you so much! It works great!
