[App][Pro] Nibe Heatpumps
I’m excited to announce the release of the Nibe MyUplink integration for Homey. Now you can control your Nibe heat pump system directly through Homey, making your home’s climate control smarter and more efficient than ever.
What can you do with it?
  • Monitor real-time temperatures and energy usage
  • Adjust heating curves and operational modes
  • Boost ventilation and hot water with one tap
  • Track performance metrics for better efficiency
  • Create smart automations with Homey
  • And more to come
Compatible with MyUplink-connected Nibe heat pump systems. Just connect through your MyUplink account, and you’re ready to go!
Give it a try and let me know what you think! :rocket:
Happy automating!
What is the difference between your app and the Nibe myuplink app
Hi!
Good question!
The functionality seems to be pretty similar the biggest difference is that my app uses oauth2 authentication.
The app you linked uses username and password authentication.
It is more flexible. It supports all kinds of MyUplink devices without hard coded assumptions on their data points.
It also allows you to choose which data points are interesting for you and use them as capabilities.
You can try both apps and see which one is better for your needs.
Thanks,
Gal
Sounds good,
If you can add the link to your app in your 1st post, its easier to find… (press the edit button below it to change it)
Thanks for clarifying that :slight_smile:
You could say that your app is for mor advanced users, since it requires users to know that X parameter corresponds to X value.
I’m curious, do you set sensor values at runtime?
I can’t believe I forgot that :sweat_smile:
Will fix immediately! Thanks for letting me know
