[APP] myUplink - Set up your indoor climate the way you want it to feel
The topic is intended for discussions about the myUplink Homey app.
Various questions, comments, and suggestions are welcome and can be posted under this topic.
Could you add support for the Nibe F730 in the app?
+1 for Nibe F739
Hello @kjson @Millegarden,
Thanks for your request. Adding support for NIBE F-series devices has been discussed within myUplink dev team, and the ticket for implementation has been created. It will be addressed according to priorities.
Hi @Denys_Kravtsov,
If you could also add Nibe F370, that would be awsome!
Since 30 aug users of Nibe Uplink cannot use that service, we are directed to MyUplink. So if you could also add the Nibe Fxx series that would be awsome!
Kind regards, Jonas
+1 for Nibe F730
TIA!
Can you add support for the CTC EcoZenith?
+1 for Nibe F730
Thanks guys - I just have connected the app myUplink app to my new Nibe S1255. Dashboard is OK and flows are also working. I’m wondering to do more e.g. read the produced thermal heat and the consumed electric power (new in NIBE SW 3.3), calculate the COP and for sure using flows to force AUX inputs to shift the output temperature. Finally I have to end up the heat pump absorbing the eccess solar energy injected in the grid
Hi!
Added the F730 as generic device but do not show the appropriate value for the hot water charging. BT6. The others seems to work fine. The BT6 value do not get any updates. Have tried to remove and er-add but didn’t work. Any advice?
@Denys_Kravtsov
Since yesterday, I keep losing contact with my water heater. Comes back when I repair the device, but falls out again almost straight away.
I’ve developed my own app for integrating with my Höiax Anima Eco Tower using a CTC EcoLogic L/M communication module. I use it for monitoring—among other things, to balance out power spikes and receive error notifications. In addition, the integration provides a solid history of various measurements such as degree-days, energy consumption, and temperatures from a range of sensors. I have plans to enhance the functionality further, for example by enabling vacation mode, temporary increases in hot water supply, and adjusting modes for domestic hot water and heating (energy-saving, normal, comfort, etc.).
The reason I mention this is that I would really like to access your source code on GitHub (the link currently returns a 404) if possible. If you’re interested, I’d be happy to contribute parameters from my setup to the codebase.
Nice app! Support for F370 would be greatly appreciated
MyUplink and CTC i250 with new display.
I just upgraded to the new display for EcoZenith i255, which gives me myUplink.
I have the myUplink running and can see the heat pump there, but when I try connect it with Homey, no devices are found when using the CTC device. But when I choose generic device I get that one is found. Please help me get the CTC device running, since I do not what to specify every parameter I want to see.
Awesome app! I miss support for F2050-10 though. Is this something you guys can add? God jul!
It seems like the app is missing support for CTC GSi 608, and i had to configure it as a generic device. It would be great with full support for the product.
Have you considered official support for Alpha Innotec devices?
I tried the app bit it doesn’t work. it says it’s not installed? But it is in de list with apps. Usually you have to log in on the account of the app to connect never had that option.
Dear developers, is it possible to make a driver for the Alpha innotec Ground source heat pump.
Any reason to only get “Invalid username/password” when logging into the app on Homey, when I use the same credentials when I log in through Chrome, and everything just works there..? Even with copy/paste, I get this..
