Ok, sounds good. I will add it.
I added the temp sensor offset setting and submitted version 1.4.5 for test: Ngenic Tune | Homey
Had a quick look and it looks great
thanks a lot. I will try it out and get back if there is anything. Extra nice that there is a card to set the offset. I have not seen that on other apps. It is great to have when you do as I do and try to auto-calibrate the sensors.
I donāt seem to get the exact same reading from my own api implementation via Advanced Virtual Devices and advanced flows. Will check where I probably have done some wrong maths ;p
It works great no problem with readings. Was only timing issues i.e. values read at different intervals. For my Christmas present I wish for the same possibility for humidity reading. That would be awesome ![]()
Glad to hear it works. Doing the same for humidity shouldnāt be a problem. I will add it, hopefully before Christmas then ![]()
Hej Simon, just got myself and Ngenic opto track installed to be able to also control and monitor the āfjƤrrvƤrmeā from my 2023 pro early.
My question is do I need to remove the device and add it again for the consumption to show up or is there another way to get the track readings included?
It is working fine in the Ngenic app but not shown on the Homey device.
Hej Tommy! Have you had the Track Opto added in the Homey app for a long time? It seems energy measurements were added in version 1.4.3 back in April. If your Track was added before that, you probably need to remove it and add it again. Otherwise it should probably be there. Unfortunately I donāt have a Track Opto myself so I cannot really verify if it works or not.
I got the track today and installed it during the afternoon using the ngenic app. The base tune part i have had since more than a year. I installed your app more or less at the same time as when you first released it.
I was hoping something like a repair would make it show up in Homey but couldnāt it.
I am bit reluctant to delete and add it as I would loose the history so far, but if thatās the only way then I know?
You would not be interested in trying to implement an auto discovery type of functionality? If so we could test on my system.
You should not need to uninstall the app or remove any other device (such as the Tune or sensors), I was just thinking if you had added the Track Opto a long time ago. It should find it of course but something is obviously wrong. Let me figure out a way to debug this and I will get back to you.
Ah now I understand you model the track as a separate device!! I didnāt think about that I was expecting it to show up under the tune deviceā¦
Added it and it worked fine right away!!!
Now itās obvious, but I was stuck on thinking it would show up as part of the tune deviceā¦
Thanks Simon!!
Fantastic, hope it works! ![]()
Yes it does work I can confirm!!!
As long as you realize you have to add the track as a separate device⦠![]()
Hi Simon,
Just want to check if you have had some progress on the HW module you mentioned, I would love a solution for this.
Thanks!
I put it on pause when Ngenic had to back on their attempt to force subscription fees until 2027 (in my case). But I suppose I need to start looking at it again since itās not so much time left. Hope I will have the time and manage to do it but I canāt promise anything.
In my case I also bought an EMS-ESP module to monitor and control my Bosch Compress 3800i EW heatpump so I can at least automate to prevent usage of the auxiliary electric heater when electricity prices are high, so one option for me could be to scrap the Ngenic Tune entirely. I havenāt decided yet.
Hi Simon,
Thanks for your reply, thats fine, we will just need to wait and see what happens futher on. ![]()
I just use my Ngenic sensors in the Homey at the moment, would be great if the Homey also could take care of the rest.
