[APP][Pro] Netgear Router - Network control, Presence detection, Energy monitoring
Hi Robin.
I have the test version 5.0.0 installed. I have the 2026 homey pro. And the Netgear Orbi RBR 750.
I get the message: unreachable
Diagnotic report just after restarting the homey netgear app: 49cd4dbe-e824-4470-9e89-7006819fee61
Can you take a look?
Thanks
Rogier
Did it work before with v4? Did you update firmware in the Orbi? Did you set the Orbi to use HTTPS only (in stead of HTTP)?
It seems in Homey you have http (port 80) set as SOAP port, and that the Orbi does not accept plain http (anymore).
What do you get when you go to these webpages from a browser in your network:
http://192.168.1.1:80/currentsetting.htm
https://192.168.1.1:443/currentsetting.htm
Rogier
v5.2.0 is ready for testing: Netgear Router | Homey
  • Fix login on HTTPS-only routers
  • Added router and attached device repair
  • Added manual TLS setting and wrong port/TLS warning
  • Improved restart stability and diagnostics logging
  • Netgear.js@5.2.0
@Rogier_Verheugen Please test this version. If still no luck, try re-pairing the router. If the auto-discovery fails to correctly find your routers IP and SOAP port, type it in manually. About 2 minutes after (trying) to re-pair, send a new app diagnostics report.
