[APP][Pro] Netgear Router - Network control, Presence detection, Energy monitoring
v3.2.5 is coming up:
  • Netgear package 4.3.3.
  • Fixed double flowcard naming issue.
  • App color changed.
  • German translation updated. (thx @DirkG !)
  • German and Dutch readme added.
I was hoping that, next to my Netgear R7800 router, it was possible to control my WiFi extenders (EX6200) as well with this app, either as router or as attached device. My goal was just a simple restart. Unfortunately no. I believe I was able to access these extenders ik the (old) Genie app, but login on port 80 fails. Just a quick reply if anyone has an idea to send a remote command on the LAN to restart these extenders once a day?
What happens when you do a compatibility test from the app settings (using the ip of the extender)
Posted the test result on GitHub. Thx for your efforts!
Thanks for a very useful app!
However I cannot make the presence functionality work. I think it worked briefly after installing the app but not anymore. The app doesn’t register when connected devices comes online/offline. They just appear as online all the time. Other app functionality works fine (fx WOL)
I have tried restarting the router, restarting the app, removing and re-adding my connected devices.
Any suggestions how to fix this? THX!
What is the router poll interval? 1 minute is usually ok.
Did you pair the individual wifi devices to Homey as attached device? Check the advanced settings for timeout. If you e.g. set it at 5 minutes, the device should report as disconnected about 5-6 minutes after you turn off the wifi.
And did you take a look at the logs to see what is going on (in app settings) . If all fails please do a router compatibility check and create an app diagnostics report after that.
Hi Gruijter,
Thanks for a very quick reply!
  • Device was added as attached devices
  • Timeout is set to standard (180)
When taking a look at the log I do however, see a lot of errors. I presume they are lated to the issue, but I do not know what they mean?
Latest errors:
2021-12-30 15:45:45 [8b7eeb50-30ff-4d7d-bc0a-4ce6a350f7d4] Error: device_not_found at Remote Process { code: 404 } upload_speed 0
2021-12-30 15:45:45 [8b7eeb50-30ff-4d7d-bc0a-4ce6a350f7d4] Error: device_not_found at Remote Process { code: 404 } download_speed 0
2021-12-30 15:45:45 [8b7eeb50-30ff-4d7d-bc0a-4ce6a350f7d4] Error: device_not_found at Remote Process { code: 404 } signal_strength 88
2021-12-30 15:45:45 [8b7eeb50-30ff-4d7d-bc0a-4ce6a350f7d4] Error: device_not_found at Remote Process { code: 404 } link_speed 1201
2021-12-30 15:45:45 [8b7eeb50-30ff-4d7d-bc0a-4ce6a350f7d4] Error: device_not_found at Remote Process { code: 404 } ssid XXX
2021-12-30 15:45:45 [8b7eeb50-30ff-4d7d-bc0a-4ce6a350f7d4] Error: device_not_found at Remote Process { code: 404 } device_connected true
2021-12-30 15:45:45 [err] [ManagerDrivers] [8b7eeb50-30ff-4d7d-bc0a-4ce6a350f7d4] trigger error Error: device_not_found at Remote Process { code: 404 }
If I look in the activity log under the attached device it says my iPhone was last connected two days ago, even though I’ve been in and out of the home several times since.
That is not a normal error. Is your Homey operating ok? Are you on a stable firmware. Maybe you need to do a ptp.
I have a SXR80, but can’t add the device to Homey (DevicePoll HTTP request Failed. Stattus Code: 401)
  • Firmware version 3.3.0.122
  • Log:
    2022-01-14 11:39:58 [err] [ManagerDrivers] [netgear] [d756571f-43d7-4a35-9b5e-db3718a4a621] DevicePoll This is not a valid Netgear router
    2022-01-14 11:39:58 [netgear] [d756571f-43d7-4a35-9b5e-db3718a4a621] Logging in
    2022-01-14 11:39:10 [log] [MyApp] test ready
    2022-01-14 11:39:03 [log] [MyApp] Retrieving known devices list
    2022-01-14 11:38:58 [err] [ManagerDrivers] [netgear] [d756571f-43d7-4a35-9b5e-db3718a4a621] Error: HTTP request Failed. Status Code: 401 at NetgearRouter.getCurrentSetting (/node_modules/netgear/netgear.js:274:11) at processTicksAndRejections (internal/process/task_queues.js:97:5) at async NetgearRouter.login (/node_modules/netgear/netgear.js:194:28) at async NetgearDevice.login (/drivers/netgear/driver.js:54:4) at async NetgearDevice.updateRouterDeviceState (/drivers/netgear/device.js:315:4) at async NetgearDevice.onInit (/drivers/netgear/device.js:397:4)
    2022-01-14 11:38:58 [netgear] [d756571f-43d7-4a35-9b5e-db3718a4a621] Logging in
    2022-01-14 11:38:58 [netgear] [d756571f-43d7-4a35-9b5e-db3718a4a621] Device Access Control could not be enabled
    2022-01-14 11:38:58 [netgear] [d756571f-43d7-4a35-9b5e-db3718a4a621] Access control enable requested
-Test:
========== STARTING TEST ==========
Node version: v12.16.1
Netgear package version: 4.3.3
OS: linux 4.14.15-g3c513a6eca
Info: Homey fw:7.2.1 app: 3.2.5
t = 0
trying to auto discover Netgear routers…
[{Firmware:V3.3.0.122WW,RegionTag:SXS80_WW,Region:ww,Model:SXS80,InternetConnectionStatus:Down,ParentalControlSupported:0,SOAPVersion:3.46,ReadyShareSupportedLevel:0,XCloudSupported:1,isBlankState:1,LoginMethod:2.0,orbiSupportedLevel:1,SOAP_HTTPs_Port:443,host:192.168.0.100,port:80},{Firmware:V3.3.0.122WW,RegionTag:SXS80_WW,Region:ww,Model:SXS80,InternetConnectionStatus:Down,ParentalControlSupported:0,SOAPVersion:3.46,ReadyShareSupportedLevel:0,XCloudSupported:1,isBlankState:1,LoginMethod:2.0,orbiSupportedLevel:1,SOAP_HTTPs_Port:443,host:192.168.0.101,port:80}]
t = 3.263
trying to login using method 1…
method 1 ok.
trying to login using method 2…
method 2 ok.
trying to login using auto method…
reported login method: 2
t = 4.048
trying to getInfo…
{ModelName:SXR80,Description:Netgear Smart Wizard 3.0, specification 1.6 version,SerialNumber:**********,SignalStrength:2,Firmwareversion:V3.3.0.122,SmartAgentversion:3.0,FirewallVersion:net-wall 2.0,OthersoftwareVersion:N/A,Hardwareversion:N/A,Otherhardwareversion:N/A,FirstUseDate:Sunday, 30 Sep 2007 01:10:03,DeviceName:6KY2115NAC3E1,DeviceNameUserSet:false,FirmwareDLmethod:HTTPS,FirmwareLastUpdate:2022_1.12_15:48:48,FirmwareLastChecked:2022_1.14_11:43:41,DeviceMode:0,DeviceModeCapability:0;1}
t = 6.417
trying to getSystemInfo…
{NewCPUUtilization:24,NewPhysicalMemory:32,NewMemoryUtilization:46,NewPhysicalFlash:128,NewAvailableFlash:60.99}
t = 15.036
trying to get supportFeatures…
{AccessControl:3.0,SpeedTest:2.0,GuestNetworkSchedule:1.0,TCAcceptance:1.0,SmartConnect:1.0,LightingLED:1.0,TimeZone:2.0,SatelliteInfo:2.0,NameNTGRDevice:1.0,AttachedDevice:2.0,MaxMonthlyTrafficLimitation:4293918720,AvsSupport:1.0,OrbiTribandSupport:1.0,DeviceTypeIcon:2.0,BackgroudSpeedtest:1.0,NewDeviceNoti:1.0,DeviceTagging:1.0,CDIL:1.0}
t = 15.116
trying to get the LAN configuration…
{NewLANSubnet:255.255.255.0,NewWANLAN_Subnet_Match:1,NewLANMACAddress:94A67E6EC2FD,NewLANIP:192.168.0.1,NewDHCPEnabled:true}
t = 15.488
trying to get the WAN configuration…
{NewEnable:1,NewConnectionType:Static,NewExternalIPAddress:192.168.3.120,NewSubnetMask:255.255.255.0,NewAddressingType:Static,NewDefaultGateway:192.168.3.1,NewMACAddress:94A67E6EC2FE,NewMACAddressOverride:0,NewMaxMTUSize:1468,NewDNSEnabled:1,NewDNSServers:195.130.131.4 195.130.130.4 8.8.8.8 2a02:1800:100::44:1 2a02:1800:100::44:2}
t = 15.789
trying to get the Traffic Meter Enabled Status…
Traffic Meter Enabled: true
t = 16.121
trying to get trafficMeter…
{newTodayUpload:707.29,newTodayDownload:3501,newMonthUpload:10895,newMonthDownload:23396}
t = 16.489
trying to get the Traffic Meter Options…
{newControlOption:No Limit,newNewMonthlyLimit:0,restartHour:0,restartMinute:0,restartDay:1}
t = 16.788
trying to get System Uptime (hh:mm:ss)…
3:39:04
t = 17.128
trying to get the Device configuration…
{BlankState:0,NewBlockSiteEnable:0,NewBlockSiteName:0,NewTimeZone:+01:00,NewDaylightSaving:1}
t = 17.447
trying to get Parental Control Status…
404 Not Found. The requested function/page is not available
Parental Control Enabled: [object Object]
t = 18.135
trying to get Qos Status…
Qos Enabled: [object Object]
t = 18.477
trying to get Qos Bandwidth options…
t = 18.821
trying to get available and selected WiFi channels…
Available channels 2.4G-1: Auto,1,2,3,4,5,6,7,8,9,10,11,12,13
selected channel 2.4G-1: 1
Available channels 5.0G-1: 36,40,44,48
selected channel 5.0G-1: 48
5.0G-2 channels are not available
5.0G-2 channel is not available
t = 20.808
trying to get Smart Connect Status…
Smart Connect Enabled: [object Object]
t = 21.498
trying to get router logs…
last log: [DoS Attack: ACK Scan] from source: 52.97.212.245, port 50815, Friday, January 14, 2022 11:44:08
t = 22.074
trying to get Guest Wifi Status…
2.4G-1 Guest wifi enabled: false
5.0G-1 Guest wifi enabled: false, method: 1
5.0G-2 Guest wifi is not available
t = 23.159
trying to get Device Access Control Status…
Block Device Enabled: false
t = 23.499
trying to get attachedDevices method 1…
Number of attached devices: 29
First attached device:
{IP:192.168.0.7,Name:Samsung Living,MAC:4C:C9:5E:B3:9B:76,ConnectionType:wired,Linkspeed:1000,SignalStrength:1000,AllowOrBlock:100}
t = 27.372
trying to get attachedDevices method 2…
{IP:192.168.0.7,Name:Samsung Living,NameUserSet:true,MAC:4C:C9:5E:B3:9B:76,ConnectionType:wired,PortNumber:2,Linkspeed:1000,SignalStrength:100,AllowOrBlock:Allow,Schedule:false,DeviceType:35,DeviceTypeUserSet:false,DeviceModel:Samsung,DeviceModelUserSet:false,Upload:0,Download:0,QosPriority:4,Grouping:0,SchedulePeriod:0,ConnAPMAC:94:A6:7E:6E:C2:FD,DeviceOS:Tizen,DeviceTypeV2:5,DeviceTypeNameV2:TV}
t = 34.915
trying to check newFirmware…
check newFirmware method: 2
{currentVersion:V3.3.0.122,newVersion:,releaseNote:}
t = 35.26
trying to logout…
{host:192.168.0.1,port:80,tls:false,username:admin,password:*****,timeout:18000,sessionId:A7D88AE69687E58D9A00,cookie:true,loggedIn:false,configStarted:true,soapVersion:3,loginMethod:2,getAttachedDevicesMethod:2,checkNewFirmwareMethod:2,guestWifiMethod:{get50_1:1},lastResponse:…,queue:{queue:{},overheat:1642127635622,pending:true,params:{default:{rule:common,key:common},rules:{common:{rate:3,limit:1,priority:1}},overall:{rate:10,limit:1},retryTime:2,ignoreOverallOverheat:true},heatPart:100}}
t = 35.343
test finished with 4 errors
there is something weird with the test. It runs most of the tests good. In fact it runs all the required tests needed for the Homey app. But the test is run on the router with IP 192.168.0.1, while the discovery finds two other IP addresses: 192.168.0.100 and 192.168.0.101. Did you add the correct IP address when pairing in Homey? I think you need 192.168.0.1 with port 80.
I have in total 3 orbi devices:
192.168.0.1: this is my main router
The other 2 devices (192.168.0.100 & 101) are both satellites ( WiFi 6 mesh system)
When I press the discovery button the app finds 192.168.0.100
The router I added in Homey is the .1
On the same device I ran also the test.
Interesting. What happens when you go from a browser to: http://routerlogin.net/currentsetting.htm
Can you post the result here?
And what If you go to http://routerlogin.net/
This app realy works well! Thanks Robin! Is it possible to find or store somewhere the data from the internet test? I would like to use it this way;
IF last test download speeld is lower then 50mb/s
AND phone xxx is offline
Then restart netgear router
:smiling_face_with_three_hearts:
Sure. It is available as flow token. See this example: Shared Flow | Homey
@Ian_Akkermans any feedback on this?
Hi Gruijter,
I have been a very satisfied user of your app for which I thank you. Recently I bought the Orbi RBK353 and am running into some problems. So the app detects the RBR350 and is able to show how many devices are connected. But when I add my phone as a separate device it doesn’t give me any parameters and most importantly it does not register if it is connected yes or no. I use it as an awareness signal to let my homey know if I am home or not. I have also have a RBK50 and that worked fine… Both routers are set in AP mode. Hope you have a suggestion how to make it work.
Grt
Fred
Just to clarify… both routers are not active at the same time. The RBK353 (WIFI6) is a replacement for the RBK50 (WIFI5)
Nice you have good use for my app :blush:
To solve this issue start by doing a compatibility test from the app settings, and post the result on github as an issue (the copy button takes you to the right spot)
You need a free Github account for that.
Done! It’s registered under fred737.
Thx
Hi Fred,
Thx for registering, but you haven’t pasted the result of the compatibility test there. That is what I need to do a first analysis.
Oh, my bad! I tried again and pasted the result.
Grtz
