[APP][Pro] myVaillant - Comfort for your home
Yes please, enable logging in the myVaillant app setting and sharing the logging id or sending a diagnostic report will help identifying the issue
I’ve made a diagnostic report: 7458def6-0b0d-43d5-9a90-19b9beac4048
here also a diagnostic rapport for the device unavailable error
24f211ce-8ef6-4262-963d-f57b9395c423
question concerning flow-card: “set cooling-mode to manual” this activates the cooling mode properly, but my Vaillant App shows an End-Time (3 hours) . Is it possible to activate the cooling mode without “time-out”, without end-time?
@Pallieter
I found out that the power consumption measurement of the app differs greatly from the actual use. The actual use of my heat pump this year is 1918 kWh. While Homey’s insights via this app indicate 3010 kWh consumption over this period. Can this be solved?
after activating and reactivating vacationmod a few more times it appeared to be over, however yesterday i felt the radiators were warm again. vrc700 still in vacationmode on 10°c, my insights shom me something else. temperatures go to 25.6) while we normally never put it higher then 21).
i think i have the same, thats why i wanted to check foor this:
I can set the heat to off but there is no: and heat is off card.
If that could be added or the: and on vacation mode cart. you can have a check in the flows
Created a small detected issue in this diagnostic report
d25fb44a-ff95-4be5-92be-0a2b3450ae97
Status in logic does not correspond with status in machine
hello,
this week i noticed that my radiotors were warm outside of the heating-window i set up in both my vrc-700 and the official myvaillant-app. when i checked my vrc-700 it didnt show the sun or moon. i tried rebooting thermostat and my VR940F (internetmodule), activating vacation/day-at-home… but nothing happened. then i disabled the myvaillant-app on my homey, and the moon appeared on my vrc-700. now it’s sticking to the programmed windows again, so i think there’s something overwriting values.
hi, i was a few days away, so i set my VRC 700 to “away” when it was time to return home i activated this flow (multiple time even). I saw the thermostat in homey going to 19 but a bit later it jumped back to 15. i dont have any flow setting temperature to 15°. when i came home heating was still on vacation mode.
@Pallieter I’ve added some extra feature’s and improvements. I’ve send you an email about it but it bounced. Let me know if you are open for me to commit those changes.
When i now added the VR921 it does not show the Power usage and power consumption, any ideas?
I’ve also added a fix for that in my PR, waiting for a response from @Pallieter I’ve I can push my changes.
Hi. Thank you for your work.
I have a question: I am failing to add the thermostats to Homey.
My setup:
  • ecoTEC
  • sensoNet VR 921
  • sensoComfort VRC720
  • 3x ambiSENSE TRV
I can add the VR921 and VRC720.
Any help is greatly appreciated. TIA.
