[APP][Pro] myIO - Heating, lighting and blinds from your myIO controller
Hi all,
This is the support topic for the myIO app: myIO | Homey
What is myIO?
myIO is a central home controller, developed in Hungary by myIO Smart Home Zrt. It sits on a DIN rail in the distribution cabinet and runs heating and cooling, lighting, blinds, gates and energy in one system. It works on its own, without the internet or a cloud: the timers, the automations and the heating control run on the controller. Homey is an extra on top, not a requirement.
More: myIO – The home that grows with you.
What the app does
You install it on your Homey Pro (on the same network as myIO), enter the address of your myIO and a user, then pick which devices to bring over:
  • on/off outputs and dimmable lamps
  • RGB lights (colour LED strips)
  • thermostats, one per heating or cooling zone
  • blinds (up / stop / down)
  • temperature and humidity sensors, and on V4 the universal sensors
  • the energy meter
In Homey Flows they work together with your other devices: if Homey’s weather app reports wind, for example, it can pull up the awning wired to myIO. There is also a Flow card for sending any myIO command.
It works with every myIO: V3, V4 GIGA and V4 Opta.
Good to know
  • Homey sees only what its myIO user has rights to. It is worth creating a separate user for Homey on myIO.
  • A blind is a lockout pair on myIO (UP direction first); its name in Homey is the common part of the two output names.
  • An RGB light is a myIO group whose name starts with “RGB”, with channels whose names start with R, G and B.
Questions, bug reports and ideas: here in this topic, or through Contact · myIO.
For a problem, please write the app version, your myIO model and firmware version, and what you expected to happen.
