[APP][Pro] myAudi - Connect your Audi EV or PHEV
@Patrick_Van_Deursen @Martin_Moleveld
:wrench: New in v1.0.44 — Live Debug Log
Diagnosing issues just got much easier. Instead of needing the Homey CLI, you can now capture a real-time log directly from the app settings — perfect for sharing with me when something isn’t working.
How to use it:
Step 1 — Enable verbose logging on your device Open your Audi device → :gear: Settings → scroll to Developer → set Debug aktivieren to Yes. This unlocks additional log output for that device.
Step 2 — Open the Debug Log tab Go to Homey → Settings → Apps → myAudi EV → open the Debug Log tab.
:warning: Important: The log is live and temporary — it only captures output while the settings page is open. Use a second device (tablet, laptop or second phone) so you can keep the log visible while triggering the issue on your main phone.
Step 3 — Trigger the problem On your main phone, press the button or action that isn’t working (e.g. Start climatisation, Lock/Unlock).
Step 4 — Copy & send Switch back to your second device, press ⎘ Copy and send the log to me via PM.
The log shows real-time entries with timestamps, device name and — most importantly — the exact API error if something goes wrong. This makes it much faster to pinpoint the root cause. :folded_hands:
all seems to be functioning (detection of connection, movement, KM etc). will check climate and window heating over the coming days
Can I maybe ask a small addition. is it possible to add the actual battery %? I now can select the KM
Is there no option under device settings to change this indicator or do you mean a combination?
there currently is no possibility to select it:
Do you mean a combination of Range and Battery?
like “160KM 54%”
Or just the Percentage value
like “54%”
Just added my 2021 Audi Q3 hybrid.
Not full electric but the app seems to work just fine
I will try it out for a while.
My Audi is also connected to Homey through the HomeAssistant integration…
Nice :slight_smile:
Please let me know if something does not work. If not to complicated I’ll think about adding Hybrid as an additional driver.
Well, this doesn’t look right….
I wish !!!
Could you please run the api helper and send me the output as pm?
Hi @Andi!
Great work for such closed environment…
Any chance to enable it for Plug-In (even old platform like Q7)?
Cheers!
LE: after some refresh I see all data presented for Q7 too :smiley:
:grinning_face:
Could you try to add your car?
Finally I need the API data to get some insight if/how different Plug-In Hybrids are.
Indeed it’s working :slight_smile:
At first usage everything looks great with this two exceptions: the data is missing for the Charging Power and it is not accurate for Estimated Max Range :slight_smile:
if both, that would even be better, but was at least looking for the %
Added both Options:
hi @Andi , found something, maybe you can help:
for all cards I can select my car, except for this one (at least I have not checked them all ;-)). Pick option remains empty.
and that also holds for its when card:
normal behavior:
here a couple of others:
Hi Patrick - Thank you for reporting the bug. Should be fixed in the newest version: myAudi | Homey
solved!
thanks
In the newest version, two additional widgets are now available — I’d love to hear what you think:
The font size is managed by Homey app or by code?
This is for zoomed un Android settings.
