[APP][Pro] Motionblinds - Smart window coverings by Coulisse
(post deleted by author)
Hi.
I have a small but annoying problem with my Motionblinds motors.
When I add them to Homey Pro via the app, the percentages are the opposite in Home. So 100% is fully up and 0% is fully down. It’s the opposite in the Motionblinds app, which is 100% fully down and 0% fully up.
Is there a way I can change it in Homey so it’s the same in both the app and Homey?
I use Homey 2019 early and PRO 2026. Via the MB-bridge CMD-01 I can see CMD-02-P devices in the early 2019, but not the CM-06 en CM-07. But the PRO-2026 has discovered the CM-07 and the up/down and the tilt-functionalities are available. But the CM-06 is not discovered by the PRO-2026. Is there a particular reason or is there already a solution?
Did you find any solution to this? Have the same challenge…
