Météo France
French version
Forecast, rain within the hour and weather alerts, straight from Météo-France.
Homey already knows the weather, roughly. This app makes it specific: the reading for your town, not a region; the rain expected in the next hour, minute by minute; and the official vigilance alert level for your department, the same orange and red warnings the French news reads out.
Requirements
- Homey Pro running firmware 12.2.0 or newer.
- Not available on Homey Cloud: the app runs locally only.
- France only this is Météo-France data, by commune and by department.
- No account, no API key. Pair a town and it works.
Multiples devices
Commune — one per town, and you can add as many as you like.
| Now | Temperature, feels-like, humidity, wind speed, gust and direction, pressure, cloud cover, UV index, conditions |
| Rain | Rain within the hour, rain probability, frost probability, precipitation today |
| Today | Low, high, conditions |
| Tomorrow | Low, high, conditions |
| In five hours | Temperature, feels-like, humidity, wind, pressure, cloud cover, conditions |
Vigilance: one per department, carrying the alert level for each of the nine tracked phenomena and the worst level overall:
wind · rain and flooding · thunderstorms · flooding · snow and ice · heatwave · extreme cold · avalanches · coastal flooding
Green, yellow, orange or red, exactly as Météo-France publishes them.
Three, and all three are about cloud cover because that is what a reader asked for.
| Card | Type | Arguments |
| The average cloud cover ahead is / is not below a threshold | Condition | Device, hours (1–48), threshold (0–100 %) |
| The forecast cloud cover is / is not below a threshold | Condition | Device, hours (1–48), threshold (0–100 %) |
| Read the forecast cloud cover | Action | Device, hours (1–48) → returns cloud cover and average |
Why cloud cover, of all things
A user running a heat pump wanted to know how sunny it would be at 9, at 13 and at 16, so the pump could lean on the sun instead of fighting it. That is a real question and the forecast answers it but a single value at a single hour is a poor guide. A passing cloud at 13:00 says nothing about the afternoon.
So there are two conditions, not one. The forecast cloud cover reads the hour you ask for. The average cloud cover ahead samples every hour across the window and averages them, which is what you actually want for anything with thermal inertia a heat pump, a water tank, a greenhouse.
Both report how many samples they found, so a window that falls off the end of the forecast is not silently answered with thin data.
If you have another use that needs a different card, say so below. This one exists because somebody asked.
Where the data comes from
Météo-France publishes no documentation for its API, but the one behind its mobile app is open and needs no account, the very same one used by Home Assistant’s official Météo-France integration. This app draws its readings, forecasts, rain-within-the-hour and vigilance levels from it.
The practical consequence: it is not a contract. If Météo-France changes it, the app will need a fix rather than a setting. Nothing has broken so far.
Languages
English, French, German, Spanish, Italian, Dutch.
Reporting a problem
Post here with your Homey firmware version, the app version, and the town or department concerned. If a value is missing rather than wrong, say which capability, Météo-France does not return every field for every commune, and knowing which one is blank is the whole clue.
Feedback and testers welcome.
Météo France
Prévisions, pluie dans l’heure et vigilance météo, directement depuis Météo-France.
Homey connaît déjà la météo, en gros. Cette app la rend précise : le relevé de votre commune et non d’une région, la pluie attendue dans l’heure qui vient, minute par minute, et le niveau de vigilance officiel de votre département, les mêmes oranges et rouges que lit le journal télévisé.
Prérequis
- Homey Pro en version 12.2.0 ou plus récente.
- Indisponible sur Homey Cloud : l’app fonctionne en local uniquement.
- France seulement : ce sont les données de Météo-France, par commune et par département.
- Ni compte, ni clé d’API. Appairez une commune et c’est prêt.
Multiples appareils
Commune : un par ville, autant que vous voulez.
| Maintenant | Température, ressenti, humidité, vent, rafales, direction, pression, nébulosité, indice UV, conditions |
| Pluie | Pluie dans l’heure, probabilité de pluie, probabilité de gel, précipitations du jour |
| Aujourd’hui | Minimale, maximale, conditions |
| Demain | Minimale, maximale, conditions |
| Dans cinq heures | Température, ressenti, humidité, vent, pression, nébulosité, conditions |
Vigilance — un par département, portant le niveau de chacun des neuf phénomènes suivis et le pire niveau global :
vent · pluie-inondation · orages · inondation · neige-verglas · canicule · grand froid · avalanches · vagues-submersion
Vert, jaune, orange ou rouge, exactement comme Météo-France les publie.
Cartes de Flow
Trois, et toutes les trois portent sur la nébulosité parce que c’est ce qu’un utilisateur a demandé.
| Carte | Type | Arguments |
| La nébulosité moyenne des N prochaines heures est / n’est pas sous X % | Condition | Appareil, heures (1–48), seuil (0–100 %) |
| La nébulosité dans N h est / n’est pas sous X % | Condition | Appareil, heures (1–48), seuil (0–100 %) |
| Relever la nébulosité prévue dans N h | Action | Appareil, heures (1–48) → rend la nébulosité et la moyenne |
Pourquoi la nébulosité, justement
Un utilisateur qui pilote une pompe à chaleur voulait savoir quel soleil il ferait à 9 h, à 13 h et à 16 h, pour que la pompe s’appuie dessus au lieu de lutter contre. La question est juste, et la prévision y répond — mais une valeur unique à une heure donnée est un mauvais guide. Un nuage qui passe à 13 h ne dit rien de l’après-midi.
D’où deux conditions et non une. La nébulosité dans N heures lit l’heure que vous demandez. La nébulosité moyenne des N prochaines heures échantillonne heure par heure sur toute la fenêtre et fait la moyenne, c’est ce qu’il faut pour tout ce qui a de l’inertie : une pompe à chaleur, un ballon d’eau chaude, une serre.
Les deux rendent le nombre d’échantillons trouvés, de sorte qu’une fenêtre qui dépasse la fin de la prévision ne soit pas répondue en silence sur des données trop minces.
Si vous avez un autre usage qui appelle une autre carte, dites-le ici. Celle-ci existe parce que quelqu’un l’a demandée.
D’où viennent les données
Météo-France ne publie aucune documentation pour son API, mais celle de son application mobile est ouverte et sans compte la même que celle qu’emploie l’intégration officielle Météo-France de Home Assistant. Cette app en tire ses relevés, ses prévisions, la pluie dans l’heure et les niveaux de vigilance.
La conséquence pratique : ce n’est pas un contrat. Si Météo-France la modifie, il faudra un correctif et non un réglage. Rien n’a cassé jusqu’ici.
Langues
Français, anglais, allemand, espagnol, italien, néerlandais.
Signaler un problème
Postez ici avec la version de votre Homey, celle de l’app, et la commune ou le département concerné. Si une valeur est absente plutôt que fausse, précisez laquelle : Météo-France ne renvoie pas tous les champs pour toutes les communes, et savoir lequel est vide est tout l’indice.
Retours et testeurs bienvenus.
