I do not understand the difference between these when-cards. “ulåst” translate into “unlocked”
One is a homey built-in version, and the other is one that I made. I deprecated the one that I made myself
Version 1.1.14 is now released. Some change only appears if you repair the device :’(
New features:
Charging pause/resume control via new start/stop charging flow actions
Unlock vehicle flow action
Connector status capability and charger connected/disconnected flow triggers and conditions
Car status widget now supports multiple vehicles with a native device picker
Improvements:
Geofencing: improved logging to diagnose empty zone issues
Updated protobuf schemas for vehicle commands and events
Widget persists car selection and correctly maps device UUIDs to VINs
Charge Power capability now shows correct label (“Charge Power”), unit (kW), and energy icon
Fixed capability display formats (labels, units, time formats)
Added admin account requirement to documentation
Update to the widget titel and background
Bug fixes:
Fixed vehicle commands (open/close windows, climate control) via fresh WebSocket sessions and TLS cipher order
Fixed duplicate https import that caused WebSocket startup crash
Improved flow action reliability
Widget bugs
Potential issue with “all windows are closed/open” and V-Klasse
Hi Anders,
thanks for the great work.
May I raise the following point, for cars like V-Klasse, the values for rear windows (both left and right) do not seem to be set (assume as these cannot be opened in V-Klasse and the last windows in the back do not “count” as windows").
As a consequence it seems that the card “all windows are closed/open” is not being excuted properly even though all “available” windows are closed/open.
Is this something that you could include/change in one of the following versions?
thx!
Gear work and super for making homey to know if the car is connected. Problem I have is that initial it worked, but now the connection to the car seems to be Dead. No new data is coming in to Homey
Really appreciate the effort to create this app! I do see the same as reported by Wietze_Ferwerda above, lost connection a couple of days ago and can’t repair - restarting app makes no difference. Using 1.1.14 and FYI, didn’t notice the issues for a few days after upgrading.
Hey all
I see a lot feedback on the app is not updating. I will look into it. Stay turn ![]()
Hey @KaiF
Please create a github issue to enable me to track the changes.
Hey all
Core issue was outdated ris-sdk-version header
. In short error was due to something Mercedes-Benz have changed in there end.
A version with the fix is not in testing, Mercedes-Benz | Homey
Please test and give feedback
New test version out, please see [APP][Pro] Mercedes-Benz - Stay connected to your Mercedes-Benz, wherever you are - #76 by Anders_Dissing
Great, connecting to vehicle works properly again, can’t see any other issues - well done @Anders_Dissing!
It works again, very much appreciated. . Is there a limitation on how much request to the API from Mercedes?
Yes. But unsure what the rate limitation are
Hey all
New version in testing. Version 1.1.18, change log:
Fix engine started/stopped triggers on electric vehicles, restore device repair flow, and migrate engine/ignition/climate capabilities for flow tag support
What a create work Anders thank you.
I am able to read all the data from the car with Homey. But inseem to be unable to sentralt commands to the car. What i have tried so far:
- Sound the car horn With and without lights
- Flash the lights
- Pause charging
- Resume charging
But nothing seems to happen. Is there something i am missing? Just be be sure have i added the security pin.
I have created a bug report from within homey, not sure if that is useful for you?
Are you running the homey integration/connections as the car owner/admin of the cars? Else it seems many of the functions will not work.
Hello, i am new at this. I have a Mercedes EQA 250+ and i want to add the car to Homey but i don’t know how. Is there a description how to do that?
Hey @Captcorner
- Add the app
- Add a device
- Login with the owner / admin account
- Done
