[APP][Pro] MCOHome - Adds support for MCOHome Z-wave devices
Hi Ted.
Can you add the product ID for the switches.
Current product ID not recongise by homey 2023 pro. Added as an unknown Zwave device.
hi, same problem here Current product ID not recongised by homey 2023 pro. Added as an unknown Zwave device.
Hi Ted, could you help to add the new zwave800 4 gang switches into the ID?
Hi, Latest version 2.0.0 cause some of my switches to not update status to homey app. Anyway I can revert to earlier version?
Afaik, it’s not possible.
Edit
Since there doesn’t seem to be any other way to contact the app developer besides through this Homey Community app thread, I would recommend sending the app developer an app diagnostic report with a detailed description of the problem.
Can you be more specific which devices and which capabilities are not updated anymore?
Other than the new thermostats, no changes to the other drivers were made in the app…
I restored my homey pro to a previous backup, before the app update, but still face the same issue.
All my 2 and 4 gang touch panel switches, only the 1st gang’s status updates in homey when toggled physically.
Toggling from the app is still working though.
tried removing 1 and re-adding it, but problem persist.
This issue started 21 April. Last working logs were dated 20 April.
Help!
I see traffic in developer tools when buttons are toggled, but status just don’t update except for button 1. ChatGPT says it’s homey parsing issue, maybe homey driver.
want to check is it just me? trying to decide if I want to delete the MCOHome app and reinstall, meaning I need to re-pair everything.
Hi @TedTolboom ,
Hope this from ChatGPT can help in the troubleshooting. May be due to the recent Homey firmware with a number of Z-Wave related changes.
Hi Ted,
Up to a couple of weeks my MCO Home Shutter Pannels worked perfect with the 1.5.3 App migrated from HP2018 to a HP2023. Due to issues I had to start over on HP2023.
This doesn’t work correct anymore on the new clean install with App version 2.0.0 and FW 13.2.0-rc.3
Error: Missing Capability Listener: windowcoverings_set
on the Dimmer / Slider.
Log ec0b1117-dffb-4fcc-9c73-316c2f1a8e83 (HP2023)
Same Device works on HP 2018 - Log 8f81616e-7542-41ed-bfc8-0bf7a615710e (fw 13.1.2 )
Are you a beta tester, Geurt?
Have you tested the official v13.1.5 yet?
My guess is that the problem is related to the firmware, since v13.2.0-rc.x includes a huge number of adjustments and changes related to Z-Wave.
There are also problems with scene activation on Fibaro devices, and Devolo motion sensors (Z-Wave) no longer work properly after installing v13.2.0-rc.x.
However, in all cases, the problem could also be that non-compliant capabilities were used in the apps for the affected functions.
However, I’d love to hear the perspective of a Z-Wave expert, like Ted.
Hi @TedTolboom,
Can I get some help here? All my flows that are triggered by toggling of the switch are not working due to status not updating. And I’m using MCOHome switches all over my home. Help!
Hi @TedTolboom
could you help to add the zwave 800 mh-s314 switches inside? mcohome no longer selling the previous version.
Same issue here. MCO Switches now doesn’t report state when turned on physically. Issue with the app or homey firmware?
Fixed in the latest Homey experimental firmware version v13.2.1-rc.4.
@TedTolboom I tried to add MH5-4A to Homey with this app, but appeared as generic zwave device. Do you have any idea? Shall I send you any information? Not even measured temperature can be seen.
Dear Official App maintainer,
It would be awesome if the following items would be supported:
  • F7-4A-ZB
  • F7-M2A-ZB
  • F7-MWH-ZB30
  • F7-MEH-ZB30
All items are listed and on stock at the famous smart home wholesale company in Germany. I look forward to utilise these in my projects.
