[APP][Pro] Huawei FusionSolar Manager
No, its actually 2 different batteries with correct daily data (compared with fusion solar)
Massive thanks to all the hard work.. You are awesome @Andi
Excuse a stupid question, but should I add the dongle device on top the Huawei meter, inverter and battery? I don’t want to disrupt what I have since it’s working as well as it does, so I just want to understand what the dongle devices adds in terms of features and/or monitoring..
You mean adding the sDongle as device in the app?
You could add it but it’s not required. I’ve created this device as addition because there you see the real house consumption in (in W) - if you add it. make sure to exclude from energy:
New feature in 1.1.30: Widgets for your Homey Dashboard:
  • Solar Energy Flow: hub layout, animated flow lines, SoC, hub icon, threshold settings
  • Grid Traffic Light: SoC in battery state, auto‑hide when no battery is present, threshold settings
  • Energy Balance: daily bars, midnight baseline logic, battery row
  • Battery Status: SoC bar, remaining time, capacity setting, “no battery” state
  • Daily Yield: auto‑scaling, optimizers, CO₂ with configurable factor
Wow that was great. I hope your translating this. Even thow i love the german language it is not my wifes prefered one :wink: You know the wife approval factor :wink:
Ups :grinning_face:
Please check 1.1.33
Huawei FusionSolar Manager | Homey
Hi, I was able to successfully add the SUN2000 inverter (Modbus) with the correct IP address. But no data is coming in? What could be the cause of that? (Homey Pro 2023)
edit: checked Modbus ID and it is correct (1 for inverter and 100 for dongle).
edit: updated firmware of dongle and inverter and now data is coming in
It would be great if you could rewrite your post in english - Thank you
Hello @Andi, had my solar system activated today and added all the following devices:
Now there is a difference between what is being exported/imported or “feed-in” to/from grid compared to the fusion solar app. Right now I’m 100% on battery and still shows every now and then some import from grid and export to grid instead of 0:
Can you help me check if it’s anything I did wrong?
Thanks
Welcome, and congrats on getting your system up and running! :tada:
What you’re seeing is most likely normal meter measurement noise, not a configuration problem.
Here’s why:
Small grid values at near-zero load are expected.
Even when running purely on battery, smart meters like the DTSU666 measure residual reactive power, harmonics, and switching transients. Values of ±5–30 W flickering around zero are within the accuracy tolerance of the meter hardware itself. FusionSolar maybe filters and rounds these in their app display — My app shows the raw register values.
The EMMA showing −23 W is the grid power reading at that moment. Depending on the sign convention of your setup, negative = slight export or slight import. 23 W is well within normal noise range.
That’s how it looks like on my setup (as well on battery):
Which devices of my app did you install?
-As power meter use the EMMA Power Meter → seems to be correct
-If possible, use the modbus devices (luna2000 modbus and sun 2000 modbus without emma. use the emma devices if the “normal ones do not work”). with those devices you have more options and flow cards!
BR
Andi
Ok understood, sounds about right.
Yes exactly what I did for the inverter and battery.
I will have the smart charger also installed later on he week.
From next week I will be doing some reverse engineering to try and have control via API and I will test it on a sample app for homey. I will share my findings with you so you can integrate on your app if you want.
As I discovered it’s the only option available right now and how other integrations were done. The Modbus integration is not yet developed but they allow a more frequent refreshed/update on the API for this device.
Cheers
:new_button: Version 1.1.36 — New Widget: Sensor Chart
Hey everyone! :waving_hand:
A new TEST version is available with a brand new dashboard widget I’ve been working on.
:bar_chart: Sensor Chart Widget
The new Sensor Chart widget lets you visualise up to 4 power measurement series as a smooth line chart directly on your Homey dashboard — perfect for keeping an eye on your energy flows at a glance.
Features:
  • Up to 4 configurable series — select any measure_power capability from your FusionSolar devices
  • Preconfigured layout for the typical setup: PV Output (green), Battery (blue), Grid (purple), Power Consumption (red)
  • Persistent history — data is saved across app restarts, so your chart is never empty after a reboot
  • Adjustable time range from 1 hour up to 7 days
  • Custom labels per series — override the default names with anything you like
  • Smooth curves with gradient fill, current value shown in the legend
  • Fully localised in :united_kingdom: English, :germany: German and :netherlands: Dutch
How to set it up:
  1. Add the Sensor Chart widget to your dashboard
  2. Open the widget settings and select the device for each series (the label hints tell you which device is expected for each slot)
  3. Optionally adjust the time range and custom labels
  4. Done — the chart starts filling up immediately and history is retained going forward
As always, feedback and bug reports are very welcome — please use the GitHub issue tracker and fill in the template so I have all the info I need.
Happy monitoring! :sun::battery:
TEST: Huawei FusionSolar Manager | Homey
@Andi that is excelent.
In fact I was going to suggest the option of some of the graphs/widgets like the one with PV, export, Import bar, to be able to see the day before or the last 5/7 days for example to have an overview or so if we could compare day x and day z.
Thanks
Although i can see the house consumption from the other widget, on this one it does not show as an available sensor:
Here it shows the house consumption:
On the second widget, the house consumption is calculated.
Is there any other capability on your 3 devices which show the current house consumption?
From the EMMA device there is the total of the day and the current, and it excludes the battery charging:
Try version 1.1.37
There
Danke merci
Just spotted this, the solar energy is counting even when it’s coming from battery:
Is there something you can adjust to be only the real solar generated power, or as it was charged with solar generated power it will be considered as such? But wasn’t that already counted when charging? So it is counting twice
Well as of this morning numbers seem correct:
But… not sure if there is something you can do or it’s just how homey counts data into energy tab
