[APP][Pro] Homesh Controller & Homesh Satellite - Connect Homey Pro 2023 to Homey Pro for Led, Speaker, Zwave(satellite) and network resource
Well I need to see why it is connecting on port 80.
Homes uses a homey-build in function to find and connect and the port (on normal Homeys) is never port 80.
Currently I haven’t setup a HsH tho.
Ok Arie,
Pls let me know if you need a diagnostic report, if it can help…
Odd, my answer is right below your post in the “self-hosted server” topic.
Maybe it’s hidden from you for some reason. Here’s a screenshot, Domenico:
But I’ll leave Arie to it, as he developed the Homesh app set.
Hi Peter,
Ok, but the question is: How I can change the TCP port on Homesh App…
Hope Arie can give a suggestion on that
You can’t, Domenico; you only can change the port of HSHS, to see if that helps, by editing the docker compose file. But, maybe Arie is investigating already, as Homesh should work on HSHS in theory.
https://support.homey.app/hc/en-us/articles/24010537261980-How-to-install-Homey-Self-Hosted-Server-with-Docker-on-Linux
Example:
services:
  homey-shs:
    image: ghcr.io/athombv/homey-shs:latest
    container_name: homey-shs
    restart: unless-stopped
    network_mode: host
    privileged: true
    volumes:
      - ~/.homey-shs:/homey/user
    PORT_SERVER_HTTP: 80
Hi Peter,
Ah, good suggestion. In the meantime Arie find a correction I can give a try.
So I have to stop homey-shs container and to restart it with the settings you’ve proposed.
Can I proceed also by using the docker start command instead of using docker compose file?
Hi, just tried with docker compose file but the response is the following:
docker compose -f homey-shs.yml up --detach
validating /home/deadmin68/homey-shs.yml: services.homey-shs additional properties 'PORT_SERVER_HTTP' not allowed
Any other idea?
Retried just now…
I have just restarted successfully the homey-shs container by giving the directive related to env variable PORT_SERVER_HTTP:80. I have made the correction in yml file by specifing the keyword “environment” before the directive:
services:
homey-shs:
image: Package homey-shs · GitHub
network_mode: host
privileged: true
volumes:
  • ~/.homey-shs:/homey/user
    environment:
  • PORT_SERVER_HTTP:80
Now homey shs started with the env variable in place but the result is the same. When I try to reach Satellite part on SHS from Controller part on my HPE2019 the same error rises:
connect ECONNREFUSED 192.168.1.63:80
Hope Arie can give a solution…
