Homematic IP brings your Homematic IP devices straight into Homey - no Home Assistant, no Homebridge, no extra server.
With this app, Homey connects directly to your Homematic IP access point via the Homematic IP cloud - just like the official Homematic IP app does. Home Assistant in between is no longer necessary.
Why you’ll like it
Direct connection - Homey talks to the Homematic IP cloud itself. One system less to run and maintain.
Real time - flip a wall switch or change something in the Homematic IP app and Homey shows it right away.
Set up in a minute - enter the SGTIN from the back of your access point, press the blue button twice, done.
Fits right into Homey - Flows, Energy (power and kWh per switch), zones and Apple Home via Homey’s Matter bridge.
Smart detection - devices are recognised by their function, so similar models work too.
English and German
Switch actuators with metering (e.g. HmIP-BSM, HmIP-FSM)
Dimmers (HmIP-BDT)
Radiator thermostats (HmIP-eTRV-E)
Motion and presence detectors (HmIP-SMI55, HmIP-SPI)
Running at my place
10 lights (6 switch actuators, 4 dimmers), 2 motion/presence detectors and a radiator thermostat - all moved over from Home Assistant, including my Flows and Apple Home via Matter. Home Assistant is no longer needed for Homematic IP here.
Try it (test version)
(New app ID since v0.5.0. If you still use the old test version “Homematic IP Cloud”, please switch to the new one - see the latest posts.)
Feedback and requests for other Homematic IP devices are very welcome!
What you need: a Homematic IP Access Point that is already set up in the Homematic IP app. (The CCU / RaspberryMatic is a different system and is not supported.)
This is a community app, not an official app from eQ-3, the maker of Homematic IP.
New device “Room (heating group)” – it represents a whole Homematic IP room, just like the room tile in the Homematic IP app, so it works with radiator thermostats, wall thermostats and floor heating:
room temperature and humidity
set the target temperature
switch between automatic (schedule) and manual mode
boost on/off
“heating” indicator and battery warning
flow cards for all of it (started/stopped heating, mode changed, set mode, boost …)
Available now in the test version (link in the first post).
@J_Norway this one is for your setup with the HmIP-WTH-1 and the FALMOT-C12 – add your rooms via “Room (heating group)”. I could only test it with radiator thermostats, so I’d really appreciate your feedback on whether temperature, humidity and target temperature show up correctly!
Great news – Homematic IP Cloud v0.4.1 works with my underfloor heating setup!
Thank you for implementing the new Room (heating group) device. I’ve now successfully tested it with the following hardware:
HmIP-WTH-1 – Wall thermostats
HmIP-FALMOT-C12 – Underfloor heating controller
Homey Pro, connected to ChatGPT
Test results
All four heating groups (Living Room, Bathroom, Small Bedroom and Master Bedroom) were successfully discovered and added to Homey.
Actual room temperature displayed correctly Target temperature displayed correctly Humidity readings available Automatic heating mode displayed correctly Battery status available with no warnings Target temperature successfully changed through ChatGPT → Homey → Homematic IP Cloud New target temperature confirmed in Homey Original target temperature restored successfully Automatic mode preserved Final settings verified in the official Homematic IP app
Specific control test:
I changed the Living Room target temperature from 22.0°C to 22.5°C via ChatGPT using the Homey integration.
Homey accepted the change and reported the new target temperature correctly. I then restored the original 22.0°C setting and verified that the system remained in automatic mode. The restored settings were also confirmed in the Homematic IP app.
I haven’t independently verified the physical valve movement of the FALMOT-C12 yet, nor tested boost or manual mode switching.
Conclusion
The new heating group implementation appears to work very well with the HmIP-WTH-1 + HmIP-FALMOT-C12 combination.
This is a major improvement for users with water-based underfloor heating, as it enables room-by-room temperature control directly from Homey without needing Home Assistant or additional hardware.
Thank you for the excellent work and quick implementation!
Happy to help test future updates or additional functionality.
Issue: “Too many requests” when creating or modifying Advanced Flows via ChatGPT
First of all, thanks again for your excellent work on Homematic IP Cloud. The new heating group functionality is working well with my HmIP-WTH-1 wall thermostats and HmIP-FALMOT-C12 underfloor heating controller.
However, I’ve encountered a recurring issue when using ChatGPT to create or modify Advanced Flows in Homey Pro.
Problem description
When several Advanced Flows are created or modified within a relatively short period, the integration starts rejecting requests with the following error:
“Too many requests”
ChatGPT then reports something along the lines of:
“I attempted to make the change, but the Homey connection is currently rejecting requests with ‘Too many requests’. Therefore, I was unable to save the updated Flow.”
This has happened repeatedly during sessions involving multiple Flow creations and modifications.
What is unclear
I’m not sure where the rate limiting originates:
Homey Pro / Homey API: Is there a rate limit on creating or updating Advanced Flows through external integrations such as ChatGPT?
Homematic IP Cloud: Could the Homematic IP Cloud integration be triggering or contributing to these limits?
Homematic IP Access Point / Cloud API: Could frequent interactions with Homematic IP cause rate limiting that affects subsequent operations?
Since the issue occurs during Advanced Flow programming via ChatGPT, I suspect it might be related to Homey’s API rather than the actual Homematic IP devices, but I haven’t been able to verify this.
Questions
Are you aware of any rate-limiting issues involving Homematic IP Cloud and Homey Pro?
Could the Homematic IP Cloud app contribute to excessive API requests during Flow creation or modification?
Is there a recommended delay or request frequency when programming multiple Advanced Flows?
Do you have any suggestions for identifying which component actually returns the “Too many requests” error?
I understand this might be outside the scope of your app, but I would appreciate any insights you or the community might have.
My goal is to use ChatGPT to manage Homematic IP heating schedules and Advanced Flows reliably through Homey Pro.
Thanks again for your help and for developing this integration!
thanks, good to hear the heating groups work for you!
The “Too many requests” error does not come from my app. ChatGPT saves flows through the Homey cloud, and my app is not part of that. Homey limits how many changes you can make through the cloud in a short time.
I had the same problem with an AI assistant: after a few quick changes, Homey blocked it for about 10 minutes. Now I connect to my Homey locally (Homey Web API with an API key, in my home network), and there I have no limit.
What you can do:
Ask ChatGPT to change only one flow at a time, with a short pause in between.
If you get the error, wait 10–15 minutes before you try again.
Ask ChatGPT to put several changes into one flow update instead of many small ones.
If you test boost or manual mode, please let me know how it works.
vielen Dank für deine tolle App! Ich nutze sie bereits erfolgreich mit einigen Geräten.
Wäre es möglich, auch den HmIP-BS2 (Schaltaktor für Markenschalter, 2-fach ohne Messfunktion) zu integrieren? Idealerweise so, dass beide Schaltkanäle unabhängig voneinander in Homey gesteuert werden können.
Tested. I have reduced and delayed the number of instructions from ChatGPT to my Homey. This solved the issue. For my use; your app works stable and good so far.
Thanks a lot for this app! I installed it succesfully and it seems to work well for my heating groups (4 chambers in practice). After buying the Homey Pro I was disappointed it didn’t work with Homematic Access point, so this is a great upgrade for me!
Thanks everyone for testing and for all the feedback!
@SD4191: Danke für die Anfrage! Der HmIP-BS2 sollte schon funktionieren. Die App legt für jeden Schaltkanal ein eigenes Homey-Gerät an, also bekommst du zwei Geräte, die du unabhängig steuern kannst. Füge einfach den Schaltaktor hinzu und sag mir bitte, ob es klappt.
@J_Norway: thanks for testing and the feedback, good to hear it runs stable!
Important: new app ID
To meet the requirements of the Homey App Store, I had to change the app ID. The app is now called “Homematic IP” and has a new test link:
Please install the new app, add the Access Point and your devices again, and then remove the old “Homematic IP Cloud” app. Your flows need the new devices. This version is now waiting for Athom’s review for the App Store.
This should be the last time you have to switch. With the new app ID, all future versions come as normal updates.
Next versions
I will keep extending the app after it is in the App Store. The next version will support more Homematic IP devices. I only have a limited number of Homematic IP devices myself, so I can’t test every device. Your feedback helps a lot. If you want to test it earlier, just reply here and I will let you know when it is ready.
Was looking into implementing OpenCCU setup to make use of my HomeMatic IP installation with Homey and thankfully it was so cumbersome to get the parts (seems only to be able to order from Germany..)
Your setup should work well with the device “Room (heating group)”. It shows room temperature, humidity and target temperature, and it works with floor heating (FALMOT) and wall thermostats – J_Norway and Arjo use the same setup.
If your STH sensors are assigned to a room in the Homematic IP app, the room device uses their temperature and humidity. Separate Homey devices for the STH sensors are planned for a later version.
As soon as Athom has approved the current version, I will post the next, improved version here for testing. You can then simply update the app, without setting anything up again.
I have now successfully completed the migration from Homematic IP Cloud v0.4.1 to Homematic IP v0.5.
All devices have been added again in Homey, and all my Flows and Advanced Flows have been migrated to use the devices from the new app.
It turned out to be quite a project, but I’m happy to say that the migration is now complete!
The next step is 48 hours of normal operation to see how everything performs in a real-world environment, with all my Flows and Advanced Flows running through Homematic IP v0.5.
I’m really looking forward to seeing the results and will report back with my observations.
Thank you for your continued development, commitment and effort in bringing Homematic IP to Homey. It is much appreciated!
do you see any chances that shutter actuators will be supported in the future?
We have just installed quite a few roller shutter actuators (HmIP-BROLL-2) and only one dimmer with an AP in our new home.
