Found this solution in the Heatit App Topic
Yes the z-trm6 is a z-wave device.
I hold my phone and the Homey Pro about 10cm from the trm6. It seems that the trm6 goes in timeout and shows ERR in the display. The pairing screen on the Homey app is just waiting
I will try your solution tomorrow
Yeah 10cm should be close enough.
I’m having trouble updating the firmware on my Heatit Z-TRM3 thermostat.
The update from firmware 4.0.0 to 4.0.33 completed successfully without any issues. However, when I try to update from 4.0.33 to 4.0.35, the update keeps failing.
Device: Heatit Z-TRM3
Current firmware: 4.0.33
Target firmware: 4.0.35
Previous update: 4.0.0 → 4.0.33 worked fine
Problem: Firmware update to 4.0.35 fails repeatedly
I have already tried:
- Running the update multiple times
- Excluding the thermostat from the Z-Wave network
- Including it again
- Trying the firmware update again after re-inclusion
Sometimes the update appears to reach 100%, but then it fails after the device reboots. Other times it fails before completing.
The thermostat is powered and works normally otherwise, but the update to 4.0.35 still does not complete successfully.
Has anyone else experienced this issue with the Heatit Z-TRM3 firmware update to 4.0.35?
Is there a known issue with this firmware version, or any recommended workaround?
Yes , I have the same issue .
I also have this issue
Same issue here
@b1ue3AGLE @F3006 @Rens_Hoekema @Thomas_Reiten
The issue is fixed in an upcoming release, version 4.4.2, this can already be installed via the test track on Heatit Controls | Homey
I can confirm that the firmware update from 4.0.33 to 4.0.35 now completes successfully on my Heatit Z-TRM3.
The thermostat rebooted afterward and appears to be working normally.
Thanks for resolving this in the app update!
As Homey pro 2023 should now be able to do firmware options I expexted a few to show up but nothing. I have a handful of Heatit z-trm6 and as far as I can tell they have never been updated (version 1.0). Homey is updated, the Heatit control app is v4.5 and all thermostats are listed in the Homey app. Any suggestions?
hello @HeatitControlsAB ,
Every year, starting october 1st, my floor heating is active and alternates between energy saving and comfort. As you can see in the screenshot the system was doing it’s job until after 9 october.
Since 10 october i can see that the right setting is activated at the right moment. in the homey app and the display of my Z-TRM2fx the set temperature corresponds to my flows. It just seems that the heating itself is not activated (no watts from 10 october).
This seems to occur after firmware update to v4.5.4. Is this a Bug?
has this issue been resolved, or is there still no heating?
issue was resolved yesterday. No bug in the app. Relay doesn’t switch anymore. Switched it out with a wifi7. Works like a charm.
Sorry to hear the 2fx stopped working, but good to hear you got the your heating back again.
Yesterday, I updated my Z-Temp2 to firmware version 1.2.4 (don’t remember what it was, but I think it was 1.2.x).
The update was successful, and the device works (it controls a relay via a Z-wave association), but I can no longer adjust the target temperature from Homey. I can however enable and disable the child lock from Homey, and the device does report temperature and humidity values to Homey, so the communication appears to be working.
The device is included as unsecure, which was recommended at the time I installed it (some years ago). Is there something I can do to fix this, because it is very annoying to not be able to adjust the target temperature from Homey.
I also have two Z-TRM3 thermostats in use, and these also have a firmware update available (from 4.0.0 to 4.0.35). They were also included as unsecure. Will I have the same issue if I update the firmware on these?
Hi Heatit Controls,
First of all, thanks again for all your hard work and support on this forum!
I’m having trouble pairing my Heatit Z-TRM3 with my Homey Pro. The pairing process just won’t complete.
My setup:
Homey: Homey Pro (Early 2023)
Homey firmware: 13.5.4
Heatit Controls app: 4.5.6
Thermostat: Heatit Z-TRM3
I’ve been reading through the forum and noticed that some users recommend restarting the heatit unit and trying to pair it multiple times until it eventually works. But is that really a solution, or just luck?
I also have a few questions:
Pairing distance: Does it really help to bring Homey closer to the thermostat? Since the Z-TRM3 is installed in the wall, moving it isn’t exactly convenient. But if it works, it works.
Network Wide Inclusion (NWI): I understand that Z-Wave devices can normally communicate through the mesh network. However, I’ve read that NWI isn’t always reliable during pairing, especially with secure connections. Does Homey/HEATIT support NWI for the Z-TRM3, or does pairing require a direct connection?
Legacy S0 security: I noticed the “Legacy security S0 pairing” option under Advanced Settings. Would enabling this help, or should I stick with the default S2 security?
Repeated attempts: Is there a technical reason why restarting the thermostat and trying multiple times might eventually work?
What’s the best approach here?
Any advice would be greatly appreciated!
Thanks!
Timothy
