[APP] Govee - Making your life smarter
Hello Vincent.
Can you include the govee lyra floor lamp?
Thanks again.
Also would like H6110 added!! Thank you!
@JH_Smart and @Dragafe Those led strips are now supported on test (and auto published soon)
@Robjuh the Lyra floor lamp is now also supported @Pieter_Pessers is that the one you also ask for?
@Patrick_Verwater your led strip is now also supported.
Have fun all
Thanks
Yes Vincent.
Perfect. That was the one. Thanks.
Thanks!
Possible to add in these?
H6148
H6159
H6188
Thanks!
Hi there,
Please how do I add device H619C if I don’t see it in the list?
I’ve set up an API in the app and successfully added another device.
Thank you for help
You request I add support for it first by posting here and to ensure I do it rather quick link me a nice product page so I can grab the details without having to search for them :blush:
I am trying to connect the Govee H6138. But when I try to do this it gives me this message:
Cannot read property "map"of undefined
I already restarted the app and cut the api key so the are no spaces in front of at the end.
Can someone help me?
Greetings Patrick
Please generate an diagnostic report after you receive the error than i can check the error
7ba760d7-b8ed-439a-ae9b-fc55ac52afe0
This is the code.
Seems like the API is not returning that device type at this point in time.
It is also not listed in the doc (but there are more devices not listed that do work) as supported device.
If it is an WIFI enable device, than I am afraid you have to wait till Govee updates their API.
If it does not Support Wifi, please let me know, then ill remove it from the app again.
Its not supporting wifi.
Its Bluetooth.
Kind regards ,
Patrick
Hi
here’s the product page of H619C. It would be great if you added it. Thank you
https://eu.govee.com/collections/led-strip-lights/products/govee-rgbic-wi-fi-bluetooth-led-strip-lights-with-protective-coating?variant=40598059155640
Bonsoir, pensez vous pouvoir intégrer les produits Govee avec le bridge Homey ? Merci.
Sorry my French is not good enough. Can you ask it in English please?
Good evening, do you think you can integrate Govee products with the Homey bridge? Thank you
The dev account requirements are not interesting for me to comply with. So I will not be making my apps compatible with the bridge/cloud.
The code is in devops so if others are going to adopt it and are able to comply with the requirements I am happy to reassign the app.
ok, thank you for the answer
