Du traff spikeren på hodet! Det finnes faktisk egne seksjoner for andre språk. Det er derfor vi – inkludert meg selv, som har norsk som morsmål – tar diskusjoner på andre språk andre steder, og holder denne delen på engelsk. Eller, hvis det passer seg slik, fortsetter tråden på det språket den allerede er på
Hvis jeg svarer på norsk, du på fransk, Pablo på spansk og Sergei på russisk, blir det ganske slitsomt å lese akkurat denne tråden – er du ikke enig?
Fair point! You’re totally right about keeping it clean and readable. I just got so excited finding the fix here that I jumped straight into typing. I’ll stick to the right section or use English next time. Cheers!
Ciao! I have just released a new version of the app for testing, which includes several improvements—most notably, support for complex prompts.
In the app settings, you can now save complex prompts using Markdown to provide detailed instructions for the agent. You can even create these prompts directly within the settings, ensuring they automatically use the correct names of your smart home devices. Once saved, the prompt can be triggered from any flow.
With complex prompts, you can entrust Gemini with sophisticated tasks.
For example, determining whether a room is occupied, Gemini can analyze not just motion sensors (if available), but also other factors, such as whether the lights or the TV are on or off. If the room is a bedroom, you can specify that the lights being off isn’t enough to assume the room is empty; you can also define “sleeping hours” during which the room should always be considered occupied.
In short, a single prompt allows you to delegate the control of all your home devices to Gemini, enabling it to make consistent, well-informed decisions.
