I will try with Your flow as an inspiration, thanks.
Hi there, not shire if I’m in the right place, but I’ll try anyway, I’m looking int to invest I the E330 professional cameras with home base 3, the home base3 is supported, how about the cameras? I get that I’ll probably have to connect the through the home base if they are supported and that’s just fine, does anyone know or even better use them?
@Anders_Grasmo currently not supported and will take a while before they will be supported.
This is a reversed engineered project. So Eufy is not backing this. So it takes a long time and effort to find a way to implement it
My Eufy Base 3 and Camera has stop working in my Homey Pro. Tried to repair it, but it did not help me. Then I removed it from HP, and I am now trying to connect to HP again. But HP is not finding the Base 3.
Any good ideas how to solve the problem?
The Eufy App is working.
@Oddbjorn_Folde please send a diagnostic report
New app update (
TEST: 3.19.0):
Changelog:
NEW:
1: NEW: add MiniBase Chime (T8023)
2: NEW: Add Doorbell E340 (T8214)
3: NEW: Add basis for Indoor Cam S350 (T8416) (hardware access required)
4: NEW: Add support for device which can be stand-alone and connected to Homebases
5: NEW: Migrate app to HomeyComposeFIXES:
1: FIX: Repair not working for some devices
2: FIX: T81A0 - S120 (implement missing types)
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Security | Homey
@molensky see the release above. It contains the fix for the S120 ![]()
Please let me know if it works as expected
@Fred6 FYI see post above. If you’re willing to share your device (temporarily) with me I can integrate the E330 aswell. I decided not to wait any longer on the library and do it myself ![]()
But i do need access as I don’t have the device myself.
Can u send me your email via pm?
Done! ![]()
Unfortunately still no movement feedback from Eufy to the app. Or able to set the scene.
I am able to control the light.
The error is gone when changing scene. Just doesn’t do anything either direction (Eufy<>Homey).
3be18b43-be55-4e27-b298-75392c94eb33
@molensky
Make sure your camera and Homey are in the same network. Homey has loads of errors trying to find your camera.
I’ll check the notification part
Btw you can override the IP address in the device settings if you would like that
@molensky can you also do a app restart and send me a report 1 minute after that?
Just to check if everything is there ![]()
Another restart did the trick. Got a warning for a recaptcha and after that I got notifications and light/scene control. ![]()
Haven’t tested the alarm, will do during daylight ![]()
Regarding the network, both Homey and the solar light are in the same network. They’re on different AP’s (mesh), but I haven’t seen other network issue with other devices yet. I’ll keep an eye out when I get intermittent responses. Most domotica devices have a fixed IP, will do the same for the wall light.
@molensky oeh nice! Glad it worked after restart. Let me know if you find anything which is not working ![]()
1st of all MANY MANY thanks for this App - it allows me to share these cameras with Node Red and Hubitat for notifications ![]()
Awesome.
Looks like yesterdays automatic update changed All Eufy Chimes to Doorbell ![]()
Sent us all, including the dogs a little crazy ![]()
ie when external triggers - motion sensors, gate switches, vibration sensors etc trigger they all ring the Eufy doorbell sound instead of the Beacon/Chord/Christmas etc etc
Setting any sound from the Eufy basestation will now ring the door bell sound.
Not urgent at all - I will use another device to sound external based alerts ![]()
@Busta999
Thanks
So first of all. Yesterdays update was a update to the test version of the app. Which can break stuff.
So if you don’t like that. there’s a instruction how to get back to the live version [APP][Pro] Eufy Security - #4590 by martijnpoppen
Can you elaborate a bit more on what you mean with All eufy chimes?
I’m not sure I get your issue
@Busta999 oh nice so that did work on the Homebase 3 ![]()
It never worked on the Homebase 2.
I guess the latest patches from Eufy which are inherited in the library broke it for the HB 3 aswell. As I updated the library yesterday.
I don’t think this is something which can be fixed though, but will have a look
Thanks
No problem - I have loads of ways to do this and no concern.
Did drive the dogs silly though:-). They kept thinking there was someone at the door ![]()
