[APP][Pro] Eufy Security
Never have this happen before and I got it after I downloaded the new test version, not the other test versions I tried before.
Yeah but theres nothing changed.
Its just a notification to let you know that theres a new login.
@martijnpoppen apologies for the late response, I’ve been away. I updated to the latest test version of the app, ran a test on one of the devices and sent you the diagnostics report. As before, no alerts showing on Homey but still getting them from the Eufy app.
@Julian_Isaacson see: [APP][Pro] Eufy Security - #4282 by martijnpoppen
Thanks, I’ve seen this but I’m not sure what it means.
@Julian_Isaacson it means that we have to wait for a fix
@martijnpoppen Okay, thanks for letting me know.
Thank you Martijn.
After you resolved the issue with security switching of the Homebas2, it worked and we were all happy. Unfortunately I noticed today that the Homebase2 (of which I have two) did not switch security mode initiated from a flow. Changing the security mode from the device does not work either.
Curious why it stopped working again.
@edumos which firmware do you have on your Homebase?
Hi Martijn,
3.3.0.4h
Subsystem 1.3.0.9
Hmm new firmware again.
I’ll check.
Can you try to restart the app in Homey and see if that changes anything?
New app update (TEST: 3.18.7):
Changelog:
NEW:
1: NEW: improve handling of battery and temperature
2: NEW: add debug logs for doorsensors
FIXES:
1: FIX: update Eufy library
2: FIX: force thumbnail on restart bug
3: FIX: battery handling
4: FIX: door sensors
5: FIX: ghost changes arming mode
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Security | Homey
@Julian_Isaacson @ExtraKim
I made a fix for the door sensors, can you test it?
See post above :slight_smile:
I just downloaded the new app, will go to my mailbox and check.
@Peter_Kalrsson @Stjepan_Siljac I made a fix for the Ghost changes for the security mode.
Can you check this release? Eufy Security App for Homey | Homey
I hope this fixes it.
Seems like a timing issue as HP23 is faster than HP19 this is occuring now
@Sharkys Made a new fix for battery, can you try?
You can reply in DM again :slight_smile: Eufy Security App for Homey | Homey
@martijnpoppen this seems to have fixed it, albeit there is a 30s delay. I’m just re-starting my Homey to see if that fixes it. Thank you for your hard work.
@Julian_Isaacson AWESOME :smiley:
Will also send the fix to the maintainer of the library so he can fix Homeassistant aswell :stuck_out_tongue:
Both my notifications (one for when I get mail and one for when I collect the mail) works and my indication lights turn on and off as they should. Thanks!
Nice! :tada:
