Martijn,
with both versions I cannot find the local Key for my robovac 35C (aka Geertje). Can you help?
Martijn,
Hey @Jeroen_Timmerman
Yes I can. I can use the same method as I use for the X8
If you share your Robovac with me I can check.
Iāll send my email in a DM
@martijnpoppen - I followed all your tips but get multiple types of errors when adding a Robovac C15 Max to Homey (timed out, could not find pairsession, and more). Robovac has a static IP, I THINK I have the correct strings from ADBā¦ But still no luck.
Youāre an epic boss, but can you help fix this too?
@Infern4w Probably
You can send me a diagnostic report.
More - apps - Eufy Home - settings wheel right top - send diagnostic report
da185e50-9cb1-4a7a-92bd-fdc9b2b77066
Am wondering whether Iām using the correct ālocalkeyā, used āproductIDā instead, as this is a 16-char string. Got no localkey back from ADBā¦
PS. was not able to send you a DM it seemsā¦
Iāll DM you
Hi Martin,
Thanks for the big work around this topic. Iām stuck funding the devide id etc. for my L70. Would you be kind to help me?
Thanks in advance.
Best regards,
Mark
Denmark
Hey,
I have the Eufy Robovac G10, but I canāt get it to work with Homey. I have al the information like IP, Device ID, Local Key. In the router settings the Robovac has a fixed internal IP adres. But nothing.
Did I miss something?
Regards, Guido
Hey @Kaassie
Thatās strange.
Sometimes the localkey shown in the app is wrong.
If you want I can try to get the data again for you.
Also can you send me a diagnostic report?
@Kaassie
Looks like the address you use for connecting is your public IP.
Make sure to use a internal IP.
Same problemā¦
Not sure if your details are correct. If you want you can share the Robovac with me and Iāll take a look.
Iāll dm you
Can you also share a new report?
Hey all,
Seems like there are multiple people where the Robovac stopped working in Homey.
What I can see is that Eufy Home changed the localKey in that case.
Only thing to do:
Martijn, youāre a rockstar! Thanks for helping me obtaining the keys
Hi Martijn,
Need your help again.
Just started tot add my eufy robovac 550c
Had some troubles with finding the local key etc but after switching pcās etc find the keys. Butā¦ I have a local key end a device key, i Made a fixed Ip, the robovac is on the same network as homey en firewall on router is not off because I canāt but at low setting. Every time I put in the ip, keys etc it gives a connection timeout.
Can you help?
81b22588-1808-4608-8a01-9f5437f626fd
