[APP][Pro] Eufy Clean
Frequently Asked Questions
Q1: Does this app work on my Homey?
A1: Homey Pro: YES
A2: Homey (Early 2016): YES
A3: Homey (Early 2018): YES
A4: Homey (Early 2019): YES
A5: Homey (Early 2023): YES
A6: Homey Cloud (Bridge): NO
A6.1: All old Homey’s are Pro now. (The white ball) Only with less cpu and memory.
A6.2: HOMEY is now a cloud service you can run free or with subscription and a Bridge as a local antenna.
Q2: Does this app work for my Robovac
A1: If your Robovac is not listed here. It should probably work
Q3: I get a Old Api Detected notification - What does it mean?
A1: When you get: Old API detected! - Please repair the device to use the new API. The app was rewritten because of a lot of changes in the API. You can still use this app as you were used to, however support for local devices will be removed in the future \n\n\n - Please repair the device to use the new API.
Since app version 2.0.0 > the app was rewritten to a new way of communication. This was done to communicate with new Eufy Robovac devices, like the X10 and S1.
What does this mean for you?
  1. You can stay on the current version and don’t change anything, it will keep working, but as mentioned in the notificaiton it will be changed some day.
  2. Repair your device and you’ll automatically switch to the new API.
    (You can repair via the homey webapp, right click on the device and press repair)
