[APP][Pro] Enphase Controller
Yet another Enphase quirk… Your Envoy was rebooting this morning (power loss or firmware update), and it started reporting before it had gathered all its data. At one point it reported 0 inverters connected and ~4800kwh lifetime solar production. A few polls later it reported the lifetime value of ~5900 again, so the app sees a bump of ~1100kwh “today”. It would’ve corrected at midnight, but any flows depending on this value would have gone haywire of course.
This also surfaced a different bug though that prevented the “inverter missing” alert from raising.
These things have been fixed in version 2.0.8.
Do you need to have an Fake Company/installer ID? I tried to login with my normal user ID (same as for the enphase app) emial en pass. But i get a Time-Out after 30000ms?
IP is correct double checked in my router. Also the serial number added correctly
after 10 attempts it is not added. strange behaviour in my network probally
I have a Marstek Venus E 3.0 battery connected via API. I want to make this battery visible via the Enphase controller widget. Is that possible and if possible how can I make this happen?
Thank you.
Fred
Sorry for the late reply. You do not need a company/installer login; its optional and only required if you want the on/off capability for you solar panels. Your normal end-user Enlighten login should also work fine.
The time-out indicates something different though. Maybe your Envoy is connected to a separate IoT network? Of you have network isolation enabled in your wifi settings?
There’s a small chance the reported time-out is not an actual time-out. If/when you’re sure your Homey should be able to reach the Envoy, you can try another login and send me the app diagnostic report.
Hi! Yes, the widget will take grid, solar and battery values from Enphase products automatically, but it can also work completely independent (and anything in between). In my case I have Enphase solar panels and Indevolt batteries, and the widget looks like the example below.
You will have to feed the widget with the values from other non-Enphase systems:
For battery-, home-, grid- and solarpower you’ll only need to have 3 of the 4 (either from the Enphase Controller devices installed, or fed through the action cards above) - it will calculate the remaining one automatically.
It also takes the battery SoC and current import/export tariffs, to supplement the widget information:
Also check the widget settings – it has various settings regarding the animations and behavior.
Dankjewel voor deze uitgebreide uitleg. Ik ga er morgen mee aan de slag.
Bedankt.
Version 2.1.0 is currently in testing. It adds a second widget that displays the same information in a different view:
@Fred_Koperdraat If you’re playing with the widgets, you might want to check this one out :wink:
Ha Bram,
It looks like the energy status of ‘solar energy today’ is still being considered as outdated or something, as this is the only status that does not show up blue. When changing to ‘current solar power’ or ‘solar energy overall’, it does change to blue. (As van be seen in the screenshot below)
Solar energy today isn’t outdated; it’s updated at the exact same moment as Solar energy overall.
Homey doesn’t use the blue color and lightning bolt to show whether a value is live or up to date. It only applies that styling to built-in Homey system energy capabilities (measure_power and meter_power). Because Solar energy today is a custom capability (meter_power_today), Homey displays it in plain gray text in the status indicator list (the same way it does for Last Envoy update).
Technically, switching it to a sub-capability of the built-in energy capability (like meter_power.today) would make it inherit the blue lightning bolt styling, but changing an existing capability ID would break users’ existing Flows and Insights history so I’m keeping it as-is since it’s purely cosmetic.
Ah check, thanks for the reply! That explains why the official Enphase app does have all the numbers in this style.
Although only cosmetic, when reviewing the tiles quickly it is nice and useful to have, but I understand the drawbacks of converting it. Maybe something for the backlog if there ever will be a larger update that requires changing the existing capabilities?
Hi Bram,
Apparently my PV loses connection to homey. Don’t know why. Could you look into it?
9fb72a48-a468-4c9b-b275-8a550d7edec2
