[APP][Pro] Enigma2 DVB Boxes Support
Sorry Guys,
i do not have a homey in the latest version, nor do I have a Enigma2 Receiver anymore. So I’m unable to further develop or support this App. If somebody would like to talk it on their behalf, just let me know and we can manage the transition.
Kind Regards
Hi Markus,
Unfortunately, this is sad news but it is understandable. Unfortunately I don’t have the knowledge for this - thank you anyway.
Marco
Very sad news
@Tolga , @Marco_Eis , @hreba - I did migrated to SDK3, implemented user/pass and conditional flows for standby mode - waiting for @carp3-noctem to if he agrees with transition to me to keep it alive.
Please note, even I’m noob developer, it’s working for me currently but it will be released for sure as TEST first.
What a beautiful Monday morning! Thank you for your proactive attitude, looking forward to use see it on Homey Pro :+1:t2:
@Sharkys great news. You made my day
Very great News ! Thank you for your work !
So thank you @carp3-noctem for app transfer and everyone who is keen on testing, please go ahead - enigma2 App for Homey | Homey
I tried to do minimal changes, those I would appreciate myself, currently keeping it in this shape, maybe I will play little bit around later but as mentioned, just noob :wink:
Perfect. Thanks a lot!!
Po našem díky moc :grinning:
FYI, published to live - enigma2 App for Homey | Homey
(the old version SDK2 is now gone)
1.1.2
25. 1. 2024
Readme update for Homey store
1.1.1
24. 1. 2024
Homey App store info update
1.1.0
23. 1. 2024
new author (developer Noob with ChatGPT help),SDK3 rewrite, added support for user name and password,Standby/Wake flow condition check implemented
Just a quick one - those of you having more enigma2 boxes, can you like this post ? I will take later how many likes I get to consider learning some new stuff and eg. rewriting it to device type of app…
@Sharkys big thanks for your hard work :muscle:
For me perfekt - Thank you so much, @Sharkys
Great Work !!!
@Tolga @Marco_Eis , new (experimental) version, tested on my VU+ DUO with enigma2 and latest VTI image.
Test it and let me know, how/if it works for you… naturally with debug sent.
note : current flows etc. will keep working for now but later I will be removing the old flows and old settings completely
note2 : I have also removed port from the config (it assumes you have configured OpenWebif via HTTPS and best with authentication enabled
Version 1.2.2 — Adjusted control logic and update info when Enigma2 is in standby
Version 1.2.3 — Old non-device flows depreciation (can’t be added but still will be working)
turned off / standby state VS turned on / pressed play
Openwebif works but I cant add my vu+ / OpenATV receiver by using it’s IP adress. I also did set a password in OpenATV and used root+ PW to fill out every field in the add device dialogue but test connection doesnt work. Any idea what Im doing wrong?
I can also access the box via telenet using root and password
Update: I needed to set box OpenWebif settings to authentificaton needed for web access. Checking app out now. Thanks
Hi All,
I'm having trouble with this Enigma2 app.
I've checked whether OpenWebif is working correctly.
I can access OpenWebif with 192.168.xxx.xxx after entering a user name and password.
It also works via HTTPS://192.168.xxx.xxx. Then I installed the Enigma2 app on my Homey.
When I test the connection during configuration in the app, it results in an error.
When I add a device, I can only specify the IP address (no port) but even then, no connection.
Does anyone have an explanation of how to do this and/or what I'm doing wrong?
Problem Solved, after many hours trying to install form my Laptop/browser it did not work.
Just did 1 try on my mobile and it worked !!!
Great
I'm having trouble with the Enigma2 app.
I can access OpenWebif with 192.168.xxx.xxx after entering a user name and password. It also works via HTTPS://192.168.xxx.xxx.
no connection.
Problem solved !!
After many hours of trying from my laptop/browser I tried form my mobile without any problem ??
Don’t know why but it works !!!
