Hi @Andersh , this is what worked for me.
Change the address to the .connect.athom.com address.
Also, make sure everything is up to date, but that speaks to itself. Hope this helps.
I have tried that. Based on that you have the long SSID-like adress, I asume you are running on a Homey PRO? Not Self Hosted Server? I think this is a SHS related problem.
The connect.athom.com domain is used for SHS as well, not only for Homey Pro.
Oh I see.
This might be a port forwarding issue on docker level then. I think you need the network connection to bridged like Homey Pro does for apps.
Or forward the ports required into the running image.
So for anyone wondering. It turns out that there is port issue with the integration especially for self hosted homey. The StreamDeck plugin expects Homey to listen on port 80 which the sellf hosted service does not.
As temporary workaround you could prolly use some reverse proxy to route the traffic but for proper support this might require an update of the SD plugin to support custom port setting.
Sorry about that. I cannot give you an ETA atm. Just watch this thrread for any updates.
@Shakesbeard we had this nice discussion almost a year ago, I wanted to let you know that I am done creating a new stream deck integration that requires a stream deck network module and has the ability to configure your stream deck directly from the appās settings screen.
If your interested screenshots and more information is available in this topic [App] [Pro] Stream Deck and the first version is now publicly available
