Change Log
StreamDeck Plugin - v1.12.1
- Fixed: SD+ dial press event not working.
Homey App - v2.4.0
- Added: New action flow card to push images to buttons on the StreamDeck (Requires StreamDeck plugin v1.12.0+)
StreamDeck Plugin - v1.12.0
- Added: Support for window coverings.
- Added: Support for interactive button images.
Homey App - v2.3.0
- Changed: The app settings page now shows all possible hostnames which can be used to configure the connection on the StreamDeck. (Requires StreamDeck plugin v1.10.0+)
StreamDeck Plugin - v1.10.0
- Added: Support for additional address formats for connecting to Homey, including IPv4.
Homey App - v2.2.1
- Fixed: Trigger Button compatibility issue for Homey Pro 2023.
StreamDeck Plugin - v1.9.0
- Added: Display Data now optionally can send a trigger to Homey on button press.
- Added: Display Logic Variable now optionally can send a trigger to Homey on button press.
- Updated: StreamDeck style definitions.
StreamDeck Plugin - v1.8.0
- Breaking: The new version requires recent v6 StreamDeck app.
- Fixed: Newly created logic variables display not saving initial configuration state.
- Added: Support for customizable StreamDeck+ knob controls.
Homey App - v2.2.0
- Update: Homey Pro 2023 compatibility update.
- Added: Api endpoints for upcoming SD+ knob support.
StreamDeck Plugin - v1.6.1
- Fixed: Hotfix for Fire Trigger Button not refreshing Homey hostname and access key correctly.
Homey App - v2.0.4
- Fixed: Startup error issue if no Homey variables are defined.
Homey App - v2.0.3
- Fixed: Multiple Trigger Buttons in same advanced flow not working.
Homey App - v2.0.2
- Fixed: Trigger Button not working with advanced flows.
Homey App - v2.0.1
- Fixed: Device selectors not being populated on initial setup
- Updated: Trigger button card is now using a formatted title
Homey App - v2.0.0
- Updated: Migrated Homey app to Homey App SDK v3
Homey App - v1.3.3
- Fixed capability listners not cleaned up if a device is removed from Homey
Homey App - v1.3.2
- Fixed a potential crash issue when the user has devices which are bound to manually disabled apps
Homey App - v1.3.1
- Massively reduced the app footprint (RAM & CPU)
- Greatly Improved API responsiveness
- Super secret and nifty under the hood changes for future StreamDeck plugin updates
StreamDeck Plugin - v1.6.0
- Added: Realtime Mode (LAN connections only)
The realtime mode activates automatically when using the LAN connection.
Homey App - v1.2.2
- Improved API Robustness
Homey App - v1.2.1
- Updated: API update for new logic variables feature
StreamDeck Plugin - v1.5.0
- Added: ‘Display Logic Variable’ element. Works the same as ‘Display Data’ but for logic variables.
StreamDeck Plugin - v1.4.0
- Improved: Buttons waiting on data, right after showing up, now indicate that with a little symbol of a certain ancient time measuring device.
- Improved: Build-in graphics now show as soon as possible for a better visual experience. Previously those showed up after the initial refresh was successful only.
Homey App - v1.1.0
- Updated: API update for new plugin version
StreamDeck Plugin - v1.3.0
- Added: The configuratior now shows an error message if the communication with Homey cannot be established, including the reason if detectable.
- Added: Support for cloud access has been added.
Homey App - v1.0.6
Homey App - v1.0.3
- Updated: athom-api to v3.2.3
StreamDeck Plugin - v1.2.1
- Added: Antidote for twichy toggles → The button status should now be less bouncy when toggling a boolean value.
Homey App - v1.0.2
- Maintenance only. No functional changes.
StreamDeck Plugin - v1.2.0
- Fixed: Issue where percentage values are not showing correctly.
- Added: The default mute capability toggle now shows the volume level if available.
Homey App - v1.0.1
- Initial Release
StreamDeck Plugin - v1.1.3
- Initial Release
