[APP][Pro] Elgato StreamDeck Integration - Control Homey with your StreamDeck
Further info
So, you have to disable the apps, otherwise when you add something as a generic device, if homey has the app, it uses it and the switch is installed not as a generic device.
However, if you disable the app and successfully add it as a generic device, it does show up on streamdeck.
The interesting thing is that TKB and develo have almost identical hardware but different apps.
If the switches are installed using their respective apps, either TKB or develo, stream deck doesn’t see them and cannot use them.
