[APP][Pro] DeLonghi Coffee Link - Unofficially monitor and control DeLonghi Wi-Fi coffee machines from Homey
De’Longhi Coffee Link for Homey
Control and monitor compatible De’Longhi coffee machines directly from Homey.
This community-developed app integrates supported De’Longhi Coffee Link machines with Homey and makes it possible to use your coffee machine in devices, widgets and Flows.
Features
Current functionality includes:
  • View the current coffee machine status
  • Start supported coffee drinks from Homey
  • Select a coffee recipe
  • Select a user profile where supported
  • View machine warnings and maintenance information
  • Use Flow cards for coffee machine events and actions
  • Quick control through a Homey widget
Flow support
The app can be used in Homey Flows.
Examples include:
  • Start coffee as part of your morning routine
  • Prepare a selected drink automatically
  • Trigger a Flow when the machine is ready
  • Receive alerts when the water reservoir is empty
  • Trigger maintenance notifications
  • Combine your coffee machine with presence, lighting, alarms and other Homey devices
Supported machines
The app is intended for compatible De’Longhi machines using the Coffee Link platform.
Support may differ between models because available drinks, profiles, sensors and machine functions vary between De’Longhi models.
I am currently expanding and verifying compatibility with additional Coffee Link Wi-Fi models.
If your machine is not yet listed as supported, please post the exact model number in this topic.
Example:
ECAM450.86.T
Reporting a problem
When reporting an issue, please include:
  • Exact De’Longhi model number
  • Homey model
  • Homey OS version
  • App version
  • What you were trying to do
  • What happened instead
  • Whether the machine still works normally in the De’Longhi Coffee Link app
Please do not post passwords, Wi-Fi credentials, account tokens or other private information.
Compatibility feedback
I am especially interested in feedback from users with different De’Longhi Coffee Link machines.
If pairing works with your machine, please report your model number so it can be added to the verified compatibility list.
Development
This is an independent community-developed Homey app.
It is not developed, endorsed or supported by De’Longhi.
De’Longhi, Coffee Link and related trademarks belong to their respective owners.
Support development
If you enjoy the app and would like to support continued development, a donation option is available through the Homey App Store.
Thanks for testing and helping improve De’Longhi Coffee Link for Homey.
waar vind ik de link naar deze app?
It is still in test mode. What model/type do you have. I will continue to add more devices tomorrow.
thank you!
Ik heb app geïnstalleerd. Hierna geprobeerd device toe te voegen.
Mijn koffieautomaat wordt niet gevonden. De delonghi app heeft wel connectie.
Het betreft een 450.65.g
Vanavond ga ik de app uitrollen met alle ondersteunende wifi devices. Ik heb nu alleen de 450.65.s toegevoegd.
Ik heb een update uitgerold. Wil je eens testen?
Jammer dat de apparaten alleen te bedienen zijn als ze aanstaan en je ze niet kan uitlezen of aanzetten op afstand oid
Mijn machine kan ik remote aanzetten. Welk type heb je? Ga ik het even nalopen. En het uitlezen kan straks als het goed is ook als de machine uit staat. (standby)
ik heb een eletta explore. alle 5 de beschibare types vinden mijn koffiemachine niet helaas.
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. Please translate your post into English, otherwise it will be deleted in three days to keep the thread in just one language as stated in the forum rules Welcome to the forum!
Please do also check out the categories in other languages:
Nederlands (Dutch)
If you need help, because depending on the trust level of your account, you may have limited permissions, please PM me or another moderator or reply to this post.
Hi Sibren,
Thanks for developing this app! I am testing the new De’Longhi Coffee Link app on Homey Pro, but when trying to add my machine, the pairing window fails and displays this error in the footer:
this.getManifest is not a function
It looks like an outdated method is being called in the code, which is incompatible with the current Homey SDK. Could you please look into this and release an update when you have a moment?
Thanks for your help!
What coffee machine do you have?
It is a PRIMA DONA SOUL ECAM610.75. Thanks for looking into this!
Which exact eletta explore do you have?
When adding the machine i git this message @Sibren_ter_Hove
I updated the app like 45 min ago. Can you test again?
Solved!
Does it work now?
Hi Sibren,
Thanks for the quick update! The pairing is working now for my PrimaDonna Soul ECAM610.75, and I can see the statistics and indicators in Homey (like the grounds container and filter usage).
However, I am now running into a recurring error during requests:
Timeout after 10000ms
It looks like some commands or status syncs take longer than 10 seconds to respond, causing a timeout. Would it be possible to increase the timeout threshold or optimize the polling interval?
Thanks again for your great work on this app!
