[APP][Pro] Dashboards
Feature request for dashboard setting: a time resolution setting for multiple insight graphs on the dashboard. And for each insight graph widget the possibility to choose for own resolution (like it works now), or setting for dashboard resolution. That way a user can easily switch resolution of multiple corresponding insight graphs on a dashboard.
Nothing is online, you actually download the entire source code when you browse the page.
The installable Homey Pro app will actually be bundled with the exact same files as the online version. No difference between them :muscle:
Afaik:
Just like with the homey.ink token, the only way to ‘logout’ is changing your Homey password. Then the token becomes invalid.
You’re basically requesting me to reimplement parts of Grafana. *All the developers in the room starts nodding :laughing:
But it’s not a bad idea to borrow some ideas from Grafana, this being one of them :ok_hand:
That just sounds weird. Changing your password should not affect existing OAuth2 logins. That would mean that all Homey integrations stops working when you change your password :sweat_smile:
Or maybe it’s an extra security measure to invalidate all tokens attached to the user when he changes his password?
We will not know for sure though.
Then this is not similar I guess, my bad :crazy_face:
With homey.ink it works like that afaik.
We need to ask athom if we want to know that
I’m trying something right now but can I also dim lights ? Slider is not working
Kooks nice if this will be available
Try saving the dashboard and refreshing the page. There’s a known bug in the underlying UI library I’m using :confused:
Save and refreshing working
Another question ; I’m making the dashboard now on my Chromebook but if I login on a tablet I can’t see the dashboard is that right ?
Correct. This is why I’m in anticipation for when Athom approves the installable companion-app. Then you can create dashboards the same way you add devices to your homey, and this “device” will be used to store dashboard configuration :wink:
Alright I understand it now.
Hope it will release soon then
Performance good! No “Error Log not found” in Insights tiles :slight_smile:
I wanted to check it out, but when i put in a API Key the site tells me it is not a working key. When i sign in the site keeps loading and loading and nothing happens.
I have a PRO 2023
Now I have four devices with different Homeyboards:
#1. I have a dashboard that fits on mobile screen
#2. Laptop
#3. Tablet
#4. Another tablet with a Sharptools board. When I click on a specific tile an overlay shows insights curves (Homeyboard #4).
I guess this is possible because the Homeyboards are unique on every browser.
Will it still be possible to have unique Homeyboards on different devices when the app is released?
It would be a nice workaround with a unique URL for every Homeyboard (#1 to #4).
How can I remove the granted webaccess for this website?
See this post:
When a device has a long list of capabilities (e.g. energy meter) in the edit window, it is impossible to scroll down to save button. Open on a big screen and extend the height of the browser window is a workaround, but not always an option.
