[APP][Pro&Cloud] Shelly
Pls contact the app developer as it’s mentioned in the first post of this topic, and ask them if they are willing to add the door sensor.
At the moment there is nothing else you can do except to use Homey compatible door/window sensors.
This overview about which SmartHome hubs already support the Shelly Wave Door/Window even comes from the original Shelly website, just for info:
Tip: Check which SmartHome products are already compatible with Homey before buying them.
@LundinGBG I think that the grafik you are showing is the enegy use for the whole month.
The first of januari it was 0kWh and on the 21th it was 21,85kWh in total.
The energie use for the days 15/1 to 21/1 is 2,76kWh.
Or didn’t you use the wasingmachine not at all that days?
Anyone knows how to connect to a shelly device on a different network? The device shows up in the Shelly app, so is connected to the Shelly cloud. But homey seems to only connect to Shelly devices locally. Any workaround? Thanks :blush:.
App Version 3.37.0:
I installed the test version 3.37.0 from here Shelly App für Homey | Homey
Then I wanted to install the new Shelly Dimmer Gen3. The Shelly app found the device, but then an error message appeared saying that no suitable device configuration was found. Strangely, the app version was then back to version 3.36.1.
The Dimmer Gen3 cannot currently be installed.
Tom
Help, I have a Shelly Plus 4i DC, now I have registered it with Shelly, then I can operate unlimited inputs, then connected to Homey, after which I can operate an input 5 times, after which the connection is lost if Shelly wants to charge you to use an input.
Anyone have experience with this?
Hi everyone, I have installed Shelly 2 PM on my shutters, which is recognized by the original Shelly app, but the apps in HomeyPro are not recognized. Can you give me some advice on this?
Did you try adding it by choosing ‘Any Shelly WiFi device’?
A permanent VPN connection to the remote network.
Or,
Add a Homey Cloud instance, add the remote Shelly cloud device:
… and use webhooks between both Homeys
Cloud webhook for all Homey models:
https://webhook.homey.app/[homey-id]/my_event_name_goes_here?tag=my_tag_name_goes_here
(‘Homey-id’ can be found here)
I have a Homey Pro running our own APP which is controlling devices and collecting data using flow actions on the app. Flows are set up by the user to feed data using Shelly App (v3.38.0) module “changed” trigger into our own actions to receive the data for specific measurements. When we receive an action we generally get the related changed value set in “state” with “registerRunListener(args, state)”. This works fine for Shelly Power, internal temperatures etc etc, except for add on temperature sensors connected to a Shelly Plus 1PM.
The Shelly Plus 1PM temperature sensors correctly show the temperature in the Homey App, however when we connect a “Temperature Sensor 1 has changed” trigger, we get an event when the temperature changes but “state” is empty and so we don’t know what the changed value is.
I have tried re-adding the Shelly device to Homey in the App but no change.
Any suggestions?
Yes, I had tried, it finds the device as shown in the image below, I select it and click on continue but it freezes and does not proceed with the installation.
appear timeout after 30000ms
Do you have the option to try it on a computer via the Homey web app, instead of via the mobile app?
The Shelly plus i4 add’s to homey as one device with 4 switches.
Is there a way to add it so it shows 4 separate switches /devices ?
Attached picture of homey and Shelly app.
The Shelly rgb device has a feature like this , if you use 4 led strips instead of rgb it will add to homey as 4 separate led controllers.
Pls always read the 1st post of app topics on how to reach the developer:
This Shelly app developer f.i. doesn’t read along…
Sorry about that. Will do as described in 1st post. Thanks.
Sorry isn’t needed, but thanks anyway.
In most app topics the dev reads along, but with this app the dev chose an other preferred way for help and support.
Hello, could you please add the Shelly 3EM-63 Gen3 device?
Please check the first post on how to contact the developer for such requests.
It is still not possible to add the device,.
Regards Frank
Did you contact the developer via their e-mail address, as indicated before?
I have the same exact question but I’m starting right now to deploy Blu devices. I do not understand if the plus acting as a Bluetooth Proxy should be directly connected with all blu devices ( it means that I need bluetooth gateway devices for shelly app and bluetooth proxy devices for homey ) or just I need one only in the whole house for all blu devices.
In your case does your devices are within a distance that can communicate with bluetooth or not?
